Intel® ARC™ Graphics
3332 Discussions
Table of DeviceIDs is using O (oh) instead of 0 (zero)
Alecazam
Since a C++ table of device ids, names, and caps/arch doesn't seem to be available, I'm building one from the website page found here.  But 6 of the deviceIDs are using O for 0.   This throws off parsing the data.
https://dgpu-docs.intel.com/devices/hardware-table.html
Look closely at these recent entries.
OBDA
Intel® Data Center GPU Max 1100
XeHPC
Intel® Data Center GPU Max Series
0BD9, OBDB, OBD7,OBD6,0BD0
Intel® Data Center GPU Max Series(future)
XeHPC
OBD5
Intel® Data Center GPU Max 1550
XeHPC
Jean_Intel
Hello Alecazam,
To properly assist you on this matter, we would like to confirm if you are currently using an Intel Server System.
Jean O.
Jean_Intel
Hello Alecazam,
We hope you are doing fine.
Jean O.
Alecazam
No, we're not using Arc server products.  But our table needs to be complete so that we identify new vs. old id's not in the table.   This chart should have correct PCI deviceId's listed and not  erroneous ones.  And Intel dev pointed me to some C++ code, but it lacks many of the newer models.   He said they would look into fixing the table.
Jean_Intel
Hello Alecazam
Thanks for the information provided.
Let us look into this and we will get back to you at our once we have further support.
Jean O.
Jean_Intel
Hello Alecazam,
We appreciate your patience.
We would like to ask for you to point out the exact models that are missing from your table since you mentioned that it lacks newer products. Also, we would like to have more details about the missing information you need, so we can look for the right contact to make the updates if necessary.
Jean O.
Jean_Intel
Hello Alecazam,
Jean O.
Alecazam
<Named removed> (assuming at Intel) sent me a link to this table.  But it's missing a lot of the entries that are in the table that this is already posted about.  He said that they'd see about updating it, but it's also missing EU counts and frequencies and other data that would be helpful.  Wikipedia has all this data already, but it needs to be in one place.  That's about all I can provide at this time.
https://github.com/GameTechDev/gpudetect/blob/master/IntelGfx.cfg
Jean_Intel
Hello Alecazam,
We will conduct a thorough internal investigation into this matter and provide an update as soon as we obtain additional information.
Please refrain from disclosing any personal information, whether it pertains to you or a third party that is not relevant to this discussion.
Jean O.
Jean_Intel
Hello Alecazam,
After reviewing this matter, the best course of action for this is to contact the person who provided you with the information for further information.
Jean O.
Jean_Intel
Hello Alecazam,
Best regards.
Jean O.
