Intel® ARC™ Graphics
3452 Discussions
The B580 graphics card does not appear to work on ACE COMBAT™7 SKIES UNKNOWN
R7-9700X-ARC-B580
My B580 graphics card didn't seem to work on ACE COMBAT™7 SKIES UNKNOWN, and even though I had specified the B580 in my Windows11 display card Settings, the game ended up using the cpu's integrated graphics card.
DeancR_Intel
Hi R7-9700X-ARC-B580,
Thank you for posting in the Community!
I would like to clarify more details about the issue so I can assist you effectively.
Tell us the name of the game or application and where to obtain it (Steam, Epic, etc.)
Are there any error codes occurring? If yes, please provide a screenshot of the error.
Have you performed other troubleshooting steps?
Please provide an application event viewer log from your system. Below are the steps to generate the logs
  • Right Click on the Start Button
  • Click on Event Viewer
  • Click on the chevron of the Windows Logs
  • Right Click on the Application and select Save All Events As
  • Save the file and send us a copy (make sure to indicate the timestamp of the crash)
Please provide an System event viewer log from your system. Below are the steps to generate the logs
  • Right Click on the System and select Save All Events As
Dean R.
R7-9700X-ARC-B580
I played this game on steam and there were no errors, the game just didn't use a B580 graphics card, no matter how I set up the game to not use a B580 graphics card.
DeancR_Intel
I appreciate your prompt response; I would like to clarify if ReBar is enabled on your BIOS and if your Intel Arc B580 is enabled as well? If not, follow the instructions here: What Is Resizable BAR and How Do I Enable It?
To better understand your system's configuration, I kindly request that you download the Intel® System Support Utility for Windows* software.
You can find the download link here:
  1. Download and launch SSU.exe.
  2. Check the box for "Everything."
  • When the scanning is complete, click "Next."
  • Click "Save."
  • Please send the saved file to us.
Dean R.
R7-9700X-ARC-B580
ReBar is enabled
DeancR_Intel
Dean R.
Earl_Intel
Earl E.
