Intel® ARC™ Graphics
3297 Discussions
Trying to run Broken Arrow on the b580 VRAM leaks
Koi_
I've been trying everything to get my b580 to run broken arrow for more then 10mins before having vram leaks, I've already tried to use DXVK but the memory leaks still occur.
JeanetteC_Intel
Hello Koi_,
To better understand the issue and provide an effective recommendation, please share the following key information:
  1. Was the game (Broken Arrow) previously working well on this PC, or is this a first-time setup with an out-of-the-box issue?
  2. If it was previously working, what changes were made before the issue arose? (Hardware additions, software/application installations, OS and driver updates, BIOS settings changes, etc.)
  3. What graphics driver is currently installed?
Additionally, I highly appreciate you sharing your system configuration so I can fully check and provide you with an accurate fix. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save. *Attach the SSU log file as you reply.
JeanetteC.
JeanetteC_Intel
Hello Koi_,
Let us know if you have any questions.
JeanetteC.
JeanetteC_Intel
Hello Koi_,
Since I haven't received any response from you recently, I will go ahead and close this thread. If you require help in the future, please submit a new inquiry, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
