PC Specs
MotherBoard ROG STRIX Z790-A GAMING WIFI II
CPU Brand: 12th Gen Intel(R) Core(TM) i9-12900KS
Ubuntu Core 24.10
Kernel Name: Linux
Hi @Isolis,
- Please provide the SSU log report and share it here so I can review your system's configuration.
- Could you let me know the origin of the game? Where did it come from, and where did you download it?
- Is it working fine before?
- Have you tried to contact the game developer? may I know their insights?
- Kindly share some screenshots and recordings of your game settings so we can replicate and check the issue on our end using the same settings you use during gameplay.
Warm regards,
Randy T.
Hello Randy,
I ran the SSU script with sudo and that is what it came out. Attaching the file.
So I installed steam through ubuntu App that i think uses snap below, the game is call VRising and it came from the Steam store, installed through steam and using Proton for compatibility. Most of the games i have work fine out of the box, is mostly some new games that have some issues, like not been able to run Marvel Rivals or Oblivion remaster because those games complain about direxct 12 not been supported.
This game has not worked before, this is a fresh installation of the game, repairing the games does not fix the issue. Most users on Proton reports no issues on linux.
I have not contacted the developer but I doubt it is a issue solely related to this particular game, normally games does not support linux, that is why we have to use Proton for the compatibility layer, there is also graphical glitches in other games like grounded( also seems related to lighting), Cyberpunk 2077 lighting reflection on water and glass, Space marine 2 textures flickering and water with weird reflection. I tried capturing the flickering in Space Marine 2 but since it flickers, the only issue in the image is the weird water reflection. So I think most of the issues are related to lighting and reflection.
For extra consideration, I used to have the Arc 770 with this current installation and also with Pop OS that used an older version of drivers, and at least in Cyberpunk the issue was the same, issues with reflections. I mention these games for context.
For insights, Proton site for compatibility is the way to go, but in this case no reports of this specific issue but Arc 770 or B580 are not common in linux.
I attached 2 images of the current configuration of the graphics of the game, since no options have fix the issue, a standard installation should suffice or copy those config, no options set on launch on steam for this game.
Isolis
Hi @Isolis,
Thank you for sharing this information. I will begin investigating the issue and attempt to replicate it on our end. I'll post an update here or notify you directly once there are any developments. If I need further details, I'll reach out to you here. I appreciate your patience as I work on this matter.
Warm regards,
Randy T.
Hello Randy,
I have to inform i think i found the solution to what it seems are most of the issues, So this gpu+drivers+mesa also had the issue of been unable to play some games that required dx12, it complained about GPU not supporting the dx12, there is a post in this forum about installing flathub and forcing steam to use a new version of mesa that is no the one that is currently on ubuntu.
I did that, i uninstall steam from snap, installed flathub and install steams through there, i follow the instruction in that post to install mesa-git and that seems to be the fix, no weird flickering, no reflection issues, VRising lighting works properly, I can even launch oblivion remaster, i need to test if that fix marvel rivals to.
For any one that tries to do this in ubuntu, had in mind that if you use flatpack/flathub sometimes it had issues with externall SSD, so you need to manually tell flatpak to access steam with a command and restart flatpak
I would say that the major issue here although seems to be not the fault of the drivers is that the current version ubuntu/mesa in my case was causing a lot of issues and i assume some will face the same.
The post is called :
Getting ES:Oblivion Remastered Working on Intel Arc B580 (Ubuntu) – Here's How
Isolis
Hi @Isolis,
I'm glad to hear that the issue has been resolved. Thank you for sharing the steps and resolution you used to solve the problem. Your insights are invaluable and will help us assist others in the future.
With the issue resolved, I will proceed to close this case now. If you have any further questions or need assistance in the future, please don't hesitate to reach out.
Warm regards,
Randy T.
