hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
Intel® ARC™ Graphics
2608 Discusiones
Unable to install Intel ARC Control
Dj96
Nuevo Colaborador I
7.473 Vistas
after updating the driver to the latest version (31.0.101.4824) I cannot find the ARC control installed.
I've tried reverting to the previous driver with a custom install including control panel, a clean install with the latest working driver and lates driver release and a clean install after delete all driver with "DDU".
Unfortunately nothing solves my problem (see attached image).
(Expanding the details tab during installation only show "Installation failed" and start the installer as admin does not work too)
Does anyone know how to fix the problem?
0 kudos
1 Solución
Dj96
Nuevo Colaborador I
7.351 Vistas
Issue solved you can close the thread.
i figured out was some problems with CMD (doesn't open).
Tried every solution wiothout success until a clean start keeping files and apps.
Now everything works fine
Ver la solución en mensaje original publicado
5 Respuestas
AlHill
Superusuario
7.465 Vistas
Download the exe for the driver.
Then, using 7zip, open the driver exe.
Open Resources
Open Extras
There you will see a number of files, including IntelArcControl.exe
Extract IntelArcControl.exe to some folder
Execute IntelArcControl, select Install.
Now you have arc control.
Dj96
Nuevo Colaborador I
7.460 Vistas
Thanks for your time AlHill,
i just tried your method and i have a file log with the error of the installer.
[50A0:2D18][2023-09-17T00:59:25]e000: Error 0x80070643: Failed to install MSI package.
[50A0:2D18][2023-09-17T00:59:25]e000: Error 0x80070643: Failed to execute MSI package.
[5318:52D8][2023-09-17T00:59:25]e000: Error 0x80070643: Failed to configure per-machine MSI package.
[5318:52D8][2023-09-17T00:59:25]i319: Applied execute package: ArcControlMsi, result: 0x80070643, restart: None
[5318:52D8][2023-09-17T00:59:25]e000: Error 0x80070643: Failed to execute MSI package.
I think this is the error blocking the installation.
Anyway, if you need the full txt i can post it here.
Edit: meanwhile i tried Cb2077 and the performance are pretty bad. (from 75/80 fps to 35-60). I think (not sure) is related to the issue during the install
AlHill
Superusuario
7.454 Vistas
Sorry, that is all I have to offer for the install of ArcControl.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Dj96
Nuevo Colaborador I
7.451 Vistas
I'll attach a full SSU report, for further information the only changes before the drivers upadate are:
- Intel oneAPI toolkit (installed)
-Intel Distribution for Python (installed)
-Intel openVINO for webUI e GIMP (installed)
And again @AlHill many thanks for your time!
Dj96
Nuevo Colaborador I
7.352 Vistas
Responder
