Intel® ARC™ Graphics
3363 讨论
Using Speed Sync causes application programs or Windows to hang.
miyuri
新分销商 I
591 次查看
Arc B570
Driver Version: 32.0.101.7029
Microsoft Windows [Version 10.0.26100.4946]
When using Speed ​​Sync in a program that uses D3D11, the program always hangs.
In the worst case scenario, it will cause a Windows BSOD.
igdkmdnd64.sys (I think) causes the following bugcheck:
PAGE_FAULT_IN_NONPAGED_AREA
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
0 项奖励
11 回复数
JeanetteC_Intel
主持人
561 次查看
Hello miyuri,
I understand you're experiencing program crashes when using Speed Sync with D3D11 applications, and this is sometimes causing Windows blue screens with these error codes:
  • PAGE_FAULT_IN_NONPAGED_AREA
  • SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
The crashes seem to be related to the Intel graphics driver (igdkmdnd64.sys).
To help investigate this issue, please provide:
  1. Which specific applications are causing the problem
  2. An Intel SSU report
  3. Any crash dump files, if available
I look forward to your response so I can investigate this internally.
JeanetteC.
0 项奖励
miyuri
新分销商 I
542 次查看
It is desirable to either implement Speed Sync without issues or disable Speed Sync.
Programs confirmed to have experienced `crashes`, `drawing stoppage and unresponsiveness`, or `detected errors and terminated` when Speed Sync is enabled (D3D11 or D3D9, fullscreen, disable vsync).
The Division 2
https://store.ubisoft.com/us/tom-clancys-the-division-2/5b06a3984e0165fa45ffdcc5.html
Watch Dogs 2
https://store.ubisoft.com/us/watch-dogs-2/574d3a8aca1a64fb3b8b4567.html
Devil May Cry 5
https://store.steampowered.com/app/601150/Devil_May_Cry_5/
(Edit Steam\steamapps\common\Devil May Cry 5\dmc5config.ini to enable D3D11)
Gamedec - Definitive Edition
https://store.steampowered.com/app/917720/Gamedec__Definitive_Edition/
LEFT ALIVE
https://store.steampowered.com/app/714370/LEFT_ALIVE/
Resident Evil 6
https://store.steampowered.com/app/221040/Resident_Evil_6/
Sniper Elite 4
https://store.steampowered.com/app/312660/Sniper_Elite_4/
SWORD ART ONLINE Alicization Lycoris
https://store.steampowered.com/app/1009290/SWORD_ART_ONLINE_Alicization_Lycoris/
Trails in the Sky 1st Chapter (DEMO)
https://store.steampowered.com/app/3375780/Trails_in_the_Sky_1st_Chapter/
Vampire Survivors
https://store.steampowered.com/app/1794680/Vampire_Survivors/
The Witcher 3: Wild Hunt
https://store.epicgames.com/en-US/p/the-witcher-3-wild-hun
The cause of the BSOD
The Division 2
LEFT ALIVE
Valkyria Chronicles 4 Complete Edition
https://store.steampowered.com/app/790820/Valkyria_Chronicles_4_Complete_Edition/
(Disable Steam input)
A program that seems to have no problems
Fallout: New Vegas
https://store.epicgames.com/en-US/p/fallout-new-vegas
FINAL FANTASY X/X-2 HD Remaster
https://store.steampowered.com/app/359870/FINAL_FANTASY_XX2_HD_Remaster/
Others
The following error was detected in LEFT ALIVE and Sniper Elite 4.
The meanings of the error codes are as follows:
0x887A0005 DXGI_ERROR_DEVICE_REMOVED
0x887A0007 DXGI_ERROR_DEVICE_RESET
I need to send the Intel SSU output and several small memory dumps, so please send me a reply email.
0 项奖励
JeanetteC_Intel
主持人
440 次查看
Hello miyuri,
As requested, I'm sending you a private email with instructions for submitting the SSU log file and dump file. Please check your inbox, and don't forget to look in your spam or junk folders in case the email was filtered there.
JeanetteC.
0 项奖励
JeanetteC_Intel
主持人
384 次查看
Hello miyuri,
Thank you for providing the SSU logs and dump files that I requested. I'll now investigate this issue further and will share an update as soon as I have more information.
JeanetteC.
0 项奖励
JeanetteC_Intel
主持人
321 次查看
Hello miyuri,
Having checked here, the main issue is the display driver failed to respond in timely fashion. Please perform DDU and re-install the latest driver 32.0.101.7029.
Let me know how it goes.
JeanetteC.
0 项奖励
miyuri
新分销商 I
302 次查看
The above issue was the result of installing 32.0.101.7029 immediately after uninstalling using DDU.
In the first place, the timeout occurs because there is a problem with the implementation.
Again, it would be best to either implement Speed ​​Sync without any issues, or disable it altogether.
There is a newer driver, 32.0.101.8132, but it doesn't say that it has been fixed, so the problem probably still exists in 32.0.101.8132.
Please let me know when it's fixed.
0 项奖励
JeanetteC_Intel
主持人
266 次查看
Hello miyuri,
Thank you for the detailed feedback regarding the driver installation and Speed Sync implementation issue. I understand that the "timeout problem" occurred after a clean DDU installation of driver 32.0.101.7029
To proceed with further investigation, can you please try the oldest available driver (32.0.101.6874) using the DDU, for comparison to the latest one (32.0.101.8132)?
I hope to hear from you soon.
JeanetteC.
Intel Customer Support
0 项奖励
miyuri
新分销商 I
217 次查看
Please replace you with a competent technical expert.
0 项奖励
ArchieD_Intel
主持人
176 次查看
Hello miyuri,
Please check your email inbox, as we have sent you a message regarding our concern.
Thank you and have a great day ahead!
Archie D.
0 项奖励
miyuri
新分销商 I
161 次查看
I couldn't find the community using Speed Sync, but when I searched for SpeedSync, I found the following discussion that also describes the same issue.
[ARC B580]Everything crashes after driver 32.0.101.6972
https://community.intel.com/t5/Intel-ARC-Graphics/ARC-B580-Everything-crashes-after-driver-32-0-101-6972/m-p/1708001/thread-id/27719
This issue also occurs with Driver Version: 32.0.101.8132, but neither the Release Notes for 32.0.101.7029 nor those for 32.0.101.8132 list it under Known Issues.
I am a customer, not a slave.
I have made the situation sufficiently clear.
This is a problem you need to solve.
0 项奖励
ArchieD_Intel
主持人
34 次查看
Hello miyuri,
Thank you for your response. I would like to know if you're able to see my email.
In addition to this, due to system limitation, we can only have 1 issue per game per thread. I will try to reproduce the issue on my end however, please let me know which game you wish to focus on.
Thank you for your cooperation and understanding.
Archie D.
0 项奖励
回复
