Intel® ARC™ Graphics
3294 Discussões
When playing FORZA HORIZON 4, there are always inexplicable frame drops!
abmqs
Principiante
749 Visualizações
My hardware configuration is as follows: A750 8G (driver version 32.0.101.5972 WHQL) i5-12400F MSI pro H610M-E DDR4 Kingston 16G DDR4 3200MHz(8+8) KIOXIA-EXCERIA PLUS G3 SSD 1T When playing FORZA HORIZON 4, there are always inexplicable frame drops with an interval of about 10 seconds. The normal frame rate is around 60 frames per second, and when the frame drops, it will be below 10 frames per second. At this time, the graphics card occupancy rate will also be very low, about 30%.
3 Respostas
RandyT_Intel
Moderador
672 Visualizações
Hello abmqs,
Thank you for reaching out to us regarding the issue you’re experiencing with your graphics and game performance. To better assist you, I need to gather some additional information. Could you please answer the following questions?
  1. Has this issue occurred before?
  2. Can you please run the System Support Utility (SSU) and share the logs with me?
  3. How did you perform the last update? Did you use a device manager-clean installation or Display Driver Uninstaller (DDU) before updating to the latest graphics driver?
  4. May I know the origin of the game (e.g., Steam, Epic Games, etc.)?
  5. Have you updated the game version or any related applications recently?
  6. What troubleshooting steps have you tried so far to fix the issue?
  7. Have you tried rolling back to the previous graphics driver version?
  8. Could you provide screenshots or recordings of the issue so I can clearly see what’s happening?
  9. Have you made any recent changes to your system, such as Windows updates, new software installations, or hardware changes, around the time this issue started?
  10. Have you monitored the temperatures of your CPU and GPU during gameplay? Overheating could cause throttling and frame drops.
  11. What graphics settings are you using in Forza Horizon 4? Have you tried lowering the settings to see if the issue persists?
  12. Do you experience similar frame drops in other games, or is this issue specific to Forza Horizon 4
In addition kindly provide CapFrameX for further checking:
CapFrameX installation instructions:
  1. Go to https://www.capframex.com/download and download the latest version of CapframeX.
  2. Go to https://www.guru3d.com/files-details/rtss-rivatuner-statistics-server-download.html and download the latest version of RTSS.
  3. Unzip both installers and install them.
  4. Launch CapFrameX, and then close it. This is why it creates the user configuration folder.
  5. Download and unzip the file OverlayEntryConfiguration_0.json (attached in this post) with the recommended RTSS configuration.
  6. Paste this file to %userprofile%\Documents\CapFrameX\Configuration.
  7. In the Capture tab, set the "Capture time" to 0. This is to remove the preset limit on capture time.
  8. In the Overlay tab, uncheck "Auto-Disable OSD" and click the save icon.
Capturing the Performance Data:
  1. Open CapframeX and do not minimise or close it.
  2. Open the game and go to the part of the game where you need to reproduce the issue. You should see the RTSS overlay in the top left corner of your screen, with the status "<game name> ready to capture...".
  3. Press F11 to start capturing data and reproducing the issue. The status in the overlay will change to "Recording frametimes XX s".
  4. Once you have reproduced the issue, press F11 to finish the data capture. The status in the overlay will change to "Processing data.".
  5. Back to CapFrameX, you can find all the data captures in the left panel of the Analysis tab. Clicking on any one of these captures will display the results on the right.
  6. To export the captured data as a JSON file, right-click the capture and click on "Copy/paste recording file(s)".
If you encounter any difficulties in finding the %userprofile%\Documents\CapFrameX\Configuration directory, you may create a new folder named 'Configuration' within the CapFrameX folder.
Providing this information will help me diagnose the system more accurately and check for available solutions. Thank you for your cooperation, and I look forward to your response.
Randy T.
RandyT_Intel
Moderador
633 Visualizações
Hi abmqs,
I wanted to follow up regarding the questions and information we shared with you recently. Have you had a chance to review them? Your feedback is invaluable in helping us determine the next best course of action.
Please let me know if you have any thoughts or if there's anything else you need from us.
Looking forward to your response!
Randy T.
RandyT_Intel
Moderador
584 Visualizações
Hi abmqs,
Since I have not received any response from you, I will proceed with closing this ticket. Please note that this case will no longer be monitored.
If you have any new questions or inquiries, kindly submit another ticket, and we will be happy to assist you.
Randy T.
Responder
