- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
I currently run the Asrock PG Arc A770 16GB in my system and when I try to play games like Halo: Infinite (Xbox app), I'm given a warning that my GPU does not have enough memory to play the game (4GB minimum). I have to click "Skip" or "Play anyway" or other options similar the aforementioned words and I have to click through them three to four times before my game begins to load. I have noticed that as I go through the Microsoft Store or the Xbox app to look at all these games (old and new), I notice that for system requirements I apparently don't meet the GPU/V-RAM requirements; and that's despite a few of the games saying Arc A380 (6GB) is supported. And this had been going on for months when I was on Windows 11 23H2. Below is the list of steps I have taken to try to correct the issue and their result:
- I have tried troubleshooting many steps. Below is what I've tried:Updated to latest drivers. Issue continues to persist.Rolled back to each previous driver all the way down to 5522. Issue continues to persist.
- Verified ReBAR was never disabled. Issue continues to persist.
- Every time I uninstalled each set of drivers, I used DDU in Safe Mode; I also ensured any Nvidia and AMD drivers were uninstalled before uninstalling the Arc drivers. Issue continues to persist.
- Made sure Windows 11 was up to date on latest updates. Issue continues to persist.
- Ensured all games and apps were up to date via the Windows Store and their respective game stores. Issue continues to persist.
- Tried disabling the onboard GPU on my i5-136000K. Issue continues to persist.
- Updated Windows 11 to 24H2 and installed all subsequent Windows Updates. Issue continues to persist.
I have attached an SSU detailing my PC specs and other information. Also attached is the screenshot of the Error/Warning box popping up as Halo Infinite begins to load. If anyone has had this experience but have been able to eradicate it altogether, please let me know. Any assistance is appreciated.
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi L0G1C-B0M8,
Thank you for sharing all the information that you could to help with the investigation. I would like to inform you that this is a known issue and it is currently being investigated. I will get back to you as soon as possible.
Jed G.
Intel Customer Support Technicians
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello L0G1C-B0M8,
This issue is caused by the game itself failing to detect the GPU as compatible. Rest assured that Intel is actively working with the game developer to get this corrected, however we cannot provide an ETA for the fix since most of the work is on the game developer side.
Have a great day!
Jed G.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hey Jed,
I don't think it's just the developer's side. I think it might be a Windows problem as well. I say that because I was on the Microsoft Store earlier and I came across a cyberpunk style game called "Observer: System Redux". I scrolled down to the games system requirements section and I noticed that all requirements were checked, except for video memory which had a red X next to it. And I know the Arc A770 has the VRAM like I've stated before. I've attached a screenshot to help.
I've also updated to driver version 6252 WHQL, which is the latest version.
If you know of anything else I can do on my end to assist, don't hesitate to reach out to me.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hi @L0G1C-B0M8,
Thank you for your patience. I've been monitoring the issue you've encountered and found that even 3rd party graphics cards are experiencing the issue. Remaining issues will be fixed by the game developer so expect a game patch in the near future. You may contact the game developer directly for further questions or status updates.
Ernesto C.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
the issue still persists nowadays. The game hasn't been patched nor the most recent A770 drivers fixed the issue.
If I set the game to Medium settings, the game runs at 1fps
. -yes, one fps!-
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
