- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
board:ASRock h470m-hvs
GPU:sparkle titan oc a750
CPU:i3 10100
RAM:64gb g.skill ripjaws
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello cabbose2552
Thank you for posting on the Intel® ARC™ Graphics Communities.
In this case, we recommend using a 600W PSU as a minimum even though your configurations have worked before it would be better to test the GPU on a system that meets the requirements to make sure it receives the needed power for it to function properly.
I would also recommend testing different cables to discard possible damaged cables, if the issue persists, please share with us the following information:
- What type of connections are you using(HDMI, DP)?
- Are you using any type of video adapter?
- Create and share with us a log file from the Intel® System Support Utility to get more detailed information on your hardware and driver details.
Hugo O.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello cabbose2552
Have you been able to re-test your GPU in a different PSU? If the issue still continues or not possible for you to test another PSU let us know the information we requested in our previous post.
Hugo O.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Hello cabbose2552
We have not received a response from you so we will proceed to close this thread. If you are still experiencing boot issues after testing a 600W power supply or different cables, feel free to open a new topic so we can assist.
Hugo O.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
