Intel® ARC™ Graphics
3294 Discussions
arc b580 performance in PUBG
Meeko
13600kf+b580 0.1%low is too low and I found it is  stumble. And  other games in Unrel  engine V perfoerm not well .
VonM_Intel
Hi, Meeko.
Thank you for posting in our Community.
I understand your concern about the Arc B580's performance in PUBG and other Unreal Engine games. PUBG seems to be the most demanding game, with a 0.1% low. This could be due to several factors, such as the game's optimization for different graphics cards or the specific settings you're using. Let's further check the issue. Knowing your current PUBG in-game settings (graphics quality, resolution scale, etc.) would be very helpful in understanding the issue better. Also, you mentioned a low 0.1% frame rate. Could you clarify what you mean by this? Is it the 0.1% lowest frames recorded during gameplay?
You told me about your CPU and graphics model but I'd like to delve deeper and verify specifics like the precise driver versions, and any system errors. Utilizing the Intel SSU tool will enable us to collect detailed information about your system setup, which could aid in identifying the underlying cause of this issue. Additionally, If you have done any other tests please let me know the details so we don't cover the same ground twice.
Have a nice day!
Von M.
VonM_Intel
Hi, Meeko.
Von M.
jackleenandrey
Thanks for following up, Von M. I really appreciate the attentive support! I’ll review your previous response shortly and let you know if I need any additional help. It’s great to see such responsive customer service—makes a big difference.
4o
VonM_Intel
Hi, Meeko.
I have not heard back from you, I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
Meeko
Thanks for your feedback. New software driver is solving some of the problems.  And I hope you can pay more attention to these problems then feedback to engineers. Intel ARC  can be  optimized great.
BR
MEEKO.
JoshB580
PUBG thing to check:
I just had super low framerate trying pubg for the first time with this new B580 card, when warzone and fortnite were just fine - turns out the fix for me to get to super smooth framerate was go into bios and disable the radeon cpu graphics in my 9600x cpu (wasn't using it, but it was enabled)
WHOA what a change. Previously it had to be super low settings to just get what felt like 15fps, now it feels like its matching my monitors 120hz.
Mo_Jihad
Same issue, came here for a fix, and this method also worked for me - entering BIOS, disabling integrated graphics.
PubG was unplayable before this change, now it is super smooth. Thanks JoshB580.
jackleenandrey
Great to hear this fix worked for you too! Disabling integrated graphics in BIOS can really boost performance, especially in demanding games like PUBG. Big thanks to JoshB580 for sharing such a practical solution—this kind of tip makes a huge difference for players struggling with stutter or lag.
4o
jackleenandrey
It sounds like you're running into some CPU bottlenecks, especially with Unreal Engine games. Make sure your BIOS is up to date and check for any background tasks that might be affecting 0.1% lows. Also, try enabling Resizable BAR and tweaking power settings in Windows for better consistency. Unreal Engine titles can be sensitive to CPU scheduling, so even small optimizations can help smooth things out.
