Intel® ARC™ Graphics
3365 Discussions
crashes and performance issues in uncharted 4 this collection
AsterCrash
Hi, I'm having performance issues and crashes in Uncharted 4. From what I've noticed so far when there are particles or scenario changes, I was using xcapframe but the game crashed and I couldn't generate the file.
JeanetteC_Intel
Hello AsterCrash,
To get a better understanding of the issue and be able to provide an effective recommendation, please provide the missing key information here:
1) Has the game (Unchartered 4) previously worked and only started getting crashes and performance issues lately?
2) If the answer above is yes, what were the changes you made prior to the issue?
3) Are there any other games or applications that crashes or with performance issues other than this game?
4) Describe the performance issue as best as you can. E.g. FPS drop when entering ‘x’ or ‘y’ section.
5) Provide screenshots or describe the graphics settings used in-game. E.g. Ultra quality preset, video resolution, ray-tracing on, etc. etc.
JeanetteC.
AsterCrash
1. It was recently installed
3. and
4. It crashes when changing scenes
5. Ultra preset without ray tracing 1080p
JeanetteC_Intel
Hello AsterCrash,,
Thank you for providing the requested information.
Please proceed with the following steps below:
1) Kindly update the BIOS firmware to the latest version (7D24v2K).
2) Make sure that the Resizable (Re-Size) BAR is enabled.
3) Try to reinstall the latest driver (32.0.101.8132) using the Display Driver Uninstaller (DDU) to Uninstall a Graphics Driver.
If the issue persists, please:
1) For performance issue, try if can submit CapFrameX capture data (.json files) reproducing the issue. *Capture data at least 3 times to define a good performance baseline.
2) For crashes kindly share your dump/log files.
Awaiting your response.
JeanetteC.
AsterCrash
For some reason, I can't capture with xcapframe, I don't know why.
The files don't have anything related to Uncharted 4, which is very strange.
JeanetteC_Intel
Hello AsterCrash,
Thank you for the update. I understand you're having difficulty with CapFrameX capture and the files aren't showing Uncharted 4 data.
Let's troubleshoot the CapFrameX issue:
  1. Please ensure CapFrameX is running as administrator
  2. Verify that the game overlay is enabled in CapFrameX settings
  3. Try launching CapFrameX before starting Uncharted 4
  4. Check if any antivirus software is blocking CapFrameX from accessing the game
Before we proceed with the capture data, could you please confirm if you've completed the initial steps I mentioned:
If CapFrameX continues to have issues, we can explore alternative performance monitoring tools. Please let me know the results of these steps.
JeanetteC.
AsterCrash
Yes, I have the latest BIOS version.
Resize is enabled.
Yes, I uninstalled it using DDU, and I just installed the latest version of the driver using DDU on the old one.
JeanetteC_Intel
Hello AsterCrash,
Thank you for confirming those details. I'll investigate this internally and provide you with an update as soon as I have more information.
JeanetteC.
