Intel® Arc™ Discrete Graphics
3550 Discussions
intel arc a770 with DaVinci resolve choppy export
ScottDavey
I have just made a new build and have i9 1300k plus arc a770 16gb i can export without noise reduction fine but as soon as I put it on the exported file is all choppy tried with vlc and other media players. All drivers seem to be upto date
Jean_Intel
Hello ScottDavey,
Thank you for posting on the Intel️® communities. We understand that you are having issues when using  DaVinci resolve with an exported file with your Intel Arc A770.
  • What DaVinci resolve version are you using?
  • What steps have you tried to solve this issue?
  • Is this issue present since day one?
  • Could you share a video recording showing the issue?
  •  To gather more information about your system that will help us troubleshoot your issue, so please, provide us with a report using the following programs:
  • .Intel® System Support Utility (Intel SSU):
    • Open the application and click "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
  • Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Hello ScottDavey,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello ScottDavey,
Best regards.
Jean O.
