Intel® ARC™ Graphics
2029 Discussions
is there a way to boost fps on asseto corsa wich is running dx11
klt
klt
i updated my drivers by the time
EvileYe
also i updated my drivers by the time
klt
do u lag too ? on no hesi with pure
RonaldM_Intel
Hello @klt
I tested the game with my Arc A770 + Windows 11 23H2 and latest graphics driver 32.0.101.5971 and it showed solid performance both at 1440p and 4K.
See video of the built-in benchmark tool results: https://youtu.be/HSeJm1v5Pu4
Please provide the Intel SSU report so I can be more familiar with your computer configuration and try to figure out why the difference in performance results. You might also upload CapFrameX data so I can analyze it - instructions found here.
Are you running the VR version of Asseto Corsa?
I look forward to hearing from you again.
Ronald M.
klt
I use Pure and csp and i play on no hesi
Saabjock
@klt....
Assetto Corsa is one of those racing titles which runs extremely 'fluid' on ARC cards.
Do you have re-bar on?
How is the rest of your system configured...memory in the correct slots, etc?
I run Assetto Corsa fully 'kitted' out using Custom Shaders Patch, PURE and Content Manager.
I'm running in 2k and WMR on an HP Reverb G2 driven by an MSI B450 Gaming Pro Carbon AC w/ R7-5800X3D.
 What kind of power supply are you using....make/model...wattage etc?
ARC seems to like really 'clean' power to get the most out of the cards.
https://www.youtube.com/watch?v=WWkd_4Pgls8
klt
https://www.youtube.com/watch?v=yPAcTG1GX-U here is a gameplay with fps shown and arc performance tab
klt
everything on my pc is placed correctly as i know but try running the game on no hesi im getting under 50 fps constantly
klt
and u got a much more better processor than mine as i know
RonaldM_Intel
Hi @klt
Given that Pure is a 3rd party mod I would need to set the proper expectations that we can't guarantee all the bugs resulting in its interaction with the GPU will be worked on. Per example a bug might require cooperation between the driver team and the mod developer.
Please test the game on its base form to see if the issue persists, then re-install the mods (for Pure it seems you need Content Manager, CSP, and SOL installed as well). If the issue persists report it to the game dev and they can submit it through our official game development support forum: https://community.intel.com/t5/Developing-Games-on-Intel/bd-p/developing-games-graphics
Ronald M.
