Intel® ARC™ Graphics
3305 討論
xess not working in ratchet and clank
Zano4455
初學者
484 檢視
When raytraced reflections are turned on XeSS does not resolve the reflections properly. the reflections turn into a shimmery mess.
a770
driver:  32.0.101.6449
標籤 (1)
0 積分
4 回應
ACarmona_Intel
430 檢視
Hello Zano4455,
May I know when the issue started? Does the issue happen the first time that you play Ratchet and Clank?
Is it possible that you can share a video of the exact issue that you are experiencing? So, I can better visualize the problem.
And also, what steps have you taken to troubleshoot the issue? This will help me to prevent providing you with the same troubleshooting steps.
Lastly, please generate an SSU report to help me further analyze important details on your system, such as the OS build number, complete model of your system, etc. To generate the SSU report, please refer to the article: How to Get the Intel® System Support Utility Logs on Windows. Please send us the generated SSU.txt file.
Carmona A.
ACarmona_Intel
406 檢視
Hello Zano4455,
I am checking in with you to see if you already have the information that I requested in order for me to continue to further investigate our issue.
Thank you!
Carmona A.
ACarmona_Intel
376 檢視
Hello Zano4455,
This is only a quick follow-up; we just wanted to check in with you, as we haven't received any feedback from you.
Thank you.
Carmona A.
ACarmona_Intel
376 檢視
Hello Zano4455,
I hope you are doing well.
Since I have not heard back from you, I will now be closing our case.
If, in case you are just busy and still needed assistance, please submit a new question on our community: https://community.intel.com/, as this thread will no longer be monitored.
Thank you.
Carmona A.
回覆
