Intel® Arc™ Discrete Graphics
4122 Discussions
7days to die VRAM issues B580
JimyJamaica
I have the same Problems in 7days to die like others have in dayz
https://community.intel.com/t5/Intel-ARC-Graphics/Intel-Arc-B580-VRAM-Overflow-in-DayZ-VRAM-Leak/td-p/1694023
After 30min-60min the VRAM runs full and the FPS drops hard so i have to restart the game....
After i while it happens again... frustrating...
System:
AMD R5 3600X
Asus B450
Sparkle Titan B580 OC
32GB RAM DDR4
Mike_Intel
Hello JimyJamaica,
  1. Was it working fine before?
  2. If yes, what was the last change made in the system before the issue started?
  3. What are the troubleshooting steps that you tried so far?
  4. Let me also check, have you installed mods in this game?
  5. Please send a screenshot of the Graphics settings of the game.
  6. What is your game launcher.
  7. Please help generate the SSU logs of your system for me to review the hardware and the installed drivers. Please refer to this link on how to generate the logs: How to get the Intel® System Support Utility Logs on Windows*
  8. Please help capture CapframeX data of the issue. Kindly capture 3-5 minutes gameplay capturing the issue. Here are the steps on how to use CapframeX
CapFrameX Installation instructions:
  1. Go to https://www.capframex.com/download and download the latest version of CapframeX.
  2. Go to https://www.guru3d.com/files-details/rtss-rivatuner-statistics-server-download.html and download the latest version of RTSS.
  3. Unzip both installers and install them.
  4. Launch CapFrameX and then close it. This is so it creates the user Configuration folder.
  5. Download and unzip the file OverlayEntryConfiguration_0.json (attached in this post) with the recommended RTSS configuration.
  6. Paste this file to %userprofile%\Documents\CapFrameX\Configuration.
  7. In the Capture tab, set the "Capture time" to 0. This is to remove the preset limit in capture time.
  8. In the Overlay tab, uncheck "Auto-Disable OSD" and click the save icon.
Capturing the Performance Data:
  1. Open CapframeX and do NOT minimize or close it.
  2. Open the game and go to the part of the game you need to be to reproduce the issue. You should see the RTSS overlay in the top left corner of your screen, with the status "<game name> ready to capture…".
  3. Press F11 to start capturing data and reproduce the issue. The Status in the overlay will change to "Recording frametimes XX s".
  4. Once you have reproduced the issue, press F11 to finish the data capturing. The Status in the overlay will change to "Processing data".
  5. Back to CapFrameX, you can find all the data captures in the left panel of the Analysis tab. Clicking any one of these captures will display the results on the right.
  6. To export the data captured as a JSON file, right click the capture and click on "Copy/paste recording file(s)".
Michael L.
JimyJamaica
  1. Was it working fine before? -- >before what? with my old AMD Vega64 yes... with Intel B580 no
  3. What are the troubleshooting steps that you tried so far? --> enable/disable fsr, change Quality settings
  4. Let me also check, have you installed mods in this game? --> no mods stock version V2.3 (b9)
  5. Please send a screenshot of the Graphics settings of the game. --> see attachment
  6. What is your game launcher. --> Steam
  7. Please help generate the SSU logs of your system for me to review the hardware and the installed drivers. Please refer to this link on how to generate the logs: How to get the Intel® System Support Utility Logs on Windows* -->see attachment
  8. Please help capture CapframeX data of the issue. Kindly capture 3-5 minutes gameplay capturing the issue. Here are the steps on how to use CapframeX --> you wrote " Download and unzip the file OverlayEntryConfiguration_0.json (attached in this post) with the recommended RTSS configuration." there is no attachment in your post
rgds Sascha
NagyAkos512
Hi JimyJamaica!
I saw that you are using FSR upscaling option. Please try to turn that off, because FSR might cause the VRAM leak you described.
I'm just another Arc user trying to help.
Best wishes,
Ákos
Mike_Intel
Hello JimyJamaica,
Thank you for the update.
Based on your reply, let me just ask. Are you using AMD Vega64 on this system before and recently change the Graphics to Arc B580?
As for my recommendation, please try to install the latest driver using DDU method. Kindly refer to the link below for the steps and the link of the latest driver:
How to Use the Display Driver Uninstaller (DDU) to Uninstall a...
Intel® Arc™ & Iris® Xe Graphics - Windows*
Michael L.
JimyJamaica
after upgrade to the ARC B580 i install a fresh Windows10
I still need OverlayEntryConfiguration_0.json  !
rgds
Sascha
Mike_Intel
Hello JimyJamaica,
I am sorry, please check the attached file that you need.
And also. please try to perform re-install of the latest driver using DDU just to check.
Michael L.
Mike_Intel
Hello JimyJamaica,
Michael L.
Mike_Intel
Hello JimyJamaica,
I am sending another follow up on the information that I requested regarding CapeFrameX data.
Michael L.
