Intel® Arc™ Discrete Graphics
4040 Discussões
[A770] COD Warzone frametime spikes
Kofter
Principiante
2.757 Visualizações
I am getting frametime spikes when playing COD Warzone on my A770 8GB.
At an average 80 fps the frametime fluctuates between ~13ms and ~26ms.
The only pattern I see with GPU is it goes from 99% to 98% usage when the frametime spike is recorded.
Utilization of my 6 P-cores is at 50-60% average with no suspicious spikes.
I am attaching an SSU and charts of the recorded 10-minute session. The spikes at the beginning of chart are during loading screens/match start.
On the frametime chart you can also see a couple of large spikes in the first quarter, during gameplay. These spikes were felt as half-second stutters in-game.
Warzone settings are:
- 1440p + XeSS Balanced
- almost everything set to lowest
- 69% VRAM target (as per multiple online recommendations to put it below 70)
Intel Graphics settings:
- SmoothSync
- Low Latency Mode - On + Boost
- Image Sharpening - 85% (need it because XeSS blurs image)
- Adaptive Tesselation - 90%
I've done:
- clean driver reinstall with DDU - no change;
- cleared game shader cache after each graphic setting change;
- Warzone specific optimizations
1 Solução
Kofter
Principiante
2.642 Visualizações
Solution:
I needed to disable ASPM (a PCI-E power-saving feature) in BIOS settings.
I had it enabled at L1 -- this is a common recommendation to keep Intel Arc idle power draw low.
Once I disabled it, I am getting the expected frametimes, with no suspicious spikes.
Ver solução na publicação original
1 Responder
Kofter
Principiante
2.643 Visualizações
Solution:
Responder
