Intel® Arc™ Discrete Graphics
4338 Discussions
Error code 1014
Kitan
Does anyone know why I am receiving this and how it can be fixed?
JeanetteC_Intel
Hello Kitan,
I can see from your screenshot that you're encountering a compatibility message, and I'd be happy to help you resolve this. To better assist you, could you please provide the following information:
  1. What graphics driver version is currently installed on your system? (You can check this in Device Manager > Display adapters)
  2. What prompted this driver update - was it from Intel Driver & Support Assistant, Windows Update, or another source?
  3. Are you experiencing any graphics or display issues that led you to attempt this driver update, or was this a routine update?
  4. Could you please run the Intel System Support Utility (SSU) and share the log file? This will help me analyze your system configuration and identify the compatibility issue.
Once I have this information, I'll be able to provide you with a specific solution to resolve this compatibility message.
JeanetteC.
Kitan
Hello, thanks for replying but,
I already fixed
I had to delete the driver, and i used DDU to ensure no remnant remained and i manually installed it from intel.com
JeanetteC_Intel
Hello Kitan,
Thank you for sharing this update. I'm glad to hear that you have used DDU for a clean removal followed by a manual installation from intel.com, as it was the ideal solution.
With everything working properly, I'll now close this thread. Should you need help in the future, kindly create a new inquiry since this case will no longer be actively tracked.
Sincerely,
JeanetteC.
