Intel® Arc™ Discrete Graphics
4122 Discussions
How to play Counter-Strike 2 with Black Bars?
Awd
Hello, I want to play CS2 with black bars (photos attached) without -vulkan on the launch options. Because -vulkan is disabled by FACEIT anti cheat (third party competitive platform). Basically I want to play CS2 with 4:3 1024x768 black bars resolution on DX11. I tried changing my monitor settings to aspect ratio, windows resolution match the game resolution (1024x768), in IGS using Retro Scaling then integer works but it gives a vertical black bars, I can't get it working properly because the game force it to stretched. Is there any workaround to play black bars?
GPU: Arc B580
Current driver: 32.0.101.8425
Awd
So, there isn't any solution to this? Awesome, great, fantastic
De_Marchi
Open intel graphics software click on "Display", set "Scaling Mode" to GPU Scaling, then set "Scaling Method" to Preserve Aspect Ratio. Game starts in black bars for me after doing this.
JedG_Intel
Hello Awd,
I understand that you’d like to play Counter‑Strike 2 in a 4:3 resolution, but you’re currently experiencing issues. To help further troubleshoot the problem, please follow the steps outlined below.
1. Select in Windows display settings another resolution than the recommended one.
2. Go to Intel® Graphics Command Center and under the scale option select Maintain Aspect Ratio.
3. If the issue persists, contact the game developer.
In case you haven't come across it yet, we have a public article about this: Counter Strike 2* Does Not Display Black Borders When Using Aspect Ratio 4:3 in Intel® Arc™ Graphics
If you have any questions, please let me know.
Best regards
Jed G.
JedG_Intel
Hello Awd,
I wanted to check if you had the chance to review the information I posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Jed G.
JedG_Intel
Hello Awd,
Jed G.
