Intel® Arc™ Discrete Graphics
3547 Discussions
Path of exile2 FPS enhanced driver
Kenzo-_-
I'm using an Intel BattleMage b580.
I wonder if the driver optimization is in progress for path of exile2.
Compared to previously used rtx2060 super and gtx1080ti
The game frame drops and secures a frame that makes it difficult to play.
Intel's graphics driver department makes quick optimizations for related games
Derwent
I agree! Plus it is the fifth most played game on Steam.
DeancR_Intel
Hi Kenzo-_-,
Thank you for posting in the Community!
Please make sure you provide the following basic information when reporting a bug:
Numbers and statistics speak a universal language so when submitting your bug to Intel try capturing the following information:
  • Describe the performance issue as best as you can.
    • Per example: FPS drop when entering ‘x’ or ‘y’ section.
  • Provide screenshots or describe the graphics settings used in-game.
    • Per example: Ultra quality preset, video resolution, ray-tracing on, etc. etc.
  • Submit CapFrameX capture data (.json files) reproducing the issue.
    • Capture data at least 3 times to define a good performance baseline.
About CapFrameX
This is a 3rd party tool for frametimes capture and analysis based on Intel's PresentMon. The overlay is provided by Rivatuner Statistics Server (RTSS).
CapFrameX Installation instructions:
  1. Go to https://www.capframex.com/download and download the latest version of CapframeX.
  2. Go to https://www.guru3d.com/files-details/rtss-rivatuner-statistics-server-download.html and download the latest version of RTSS.
  3. Unzip both installers and install them.
  4. Launch CapFrameX and then close it. This is so it creates the user Configuration folder.
  5. Download and unzip the file OverlayEntryConfiguration_0.json (attached in this post) with the recommended RTSS configuration.
  6. Paste this file to %userprofile%\Documents\CapFrameX\Configuration.
  7. In the Capture tab, set the "Capture time" to 0. This is to remove the preset limit in capture time.
  8. In the Overlay tab, uncheck "Auto-Disable OSD" and click the save icon.
Capturing the Performance Data:
  1. Open CapframeX and do NOT minimize or close it.
  2. Open the game and go to the part of the game you need to be to reproduce the issue. You should see the RTSS overlay in the top left corner of your screen, with the status "<game name> ready to capture…".
  3. Press F11 to start capturing data and reproduce the issue. The Status in the overlay will change to "Recording frametimes XX s".
  4. Once you have reproduced the issue, press F11 to finish the data capturing. The Status in the overlay will change to "Processing data".
  5. Back to CapFrameX, you can find all the data captures in the left panel of the Analysis tab. Clicking any one of these captures will display the results on the right.
  6. To export the data captured as a JSON file, right click the capture and click on "Copy/paste recording file(s)".
  7. What is the graphics driver you are using?
  • Confirm you are using the latest driver (Intel® Graphics Driver 32.0.101.6460/32.0.101.6259) here: Intel® Arc™ & Iris® Xe Graphics - Windows* (let us know the exact driver version you are using).
  • A clean driver installation using DDU in safe mode is recommended. Follow this link for instructions.
  • You could also test using the latest non-WHQL driver. This driver goes through all Intel quality assurance processes and is safe to use for evaluation.
  1. Tell us the name of the game or application and where to obtain it (Steam, Epic, etc.)
  2. Provide us with the Intel SSU report from your system.
  • If you do not wish to submit the SSU report then at least provide us with the following information about your system:
    • Processor make and model.
    • Motherboard make and model.
    • Amount of memory (RAM).
    • Operating System version/build number.
  • Power Supply make and model.
Hi Derwent,
I suggest creating a new thread for this inquiry to avoid further confusions. Thank you.
Dean R.
Kenzo-_-
Hi
Use driver vision 32.0.101.6259
In all image quality options
The B580 is less capable than its competitors.
You have to collaborate with the game company and solve it as soon as possible.
I don't want to regret buying B580 with money.
Caston
I do agree what you asked.
I also complained about fram drop compared to my previous 1070. Please work on optimization quickly.
Let us play with better environment.
DeancR_Intel
Hi Kenzo-_-,
This is noted and I'm looking into it and will get back to you with a resolution as soon as possible.
Hi Caston,
I understand that as well however, I suggest creating a new thread for this inquiry to avoid further confusions.
Dean R.
DeancR_Intel
Hi Kenzo-_-,
I understand that you're looking for a more detailed analysis of your gameplay. The CapFrameX results you provided only run for about 2 seconds, which isn't enough for a thorough review. Could you please share a longer CapFrameX recording, ideally playing the game for at least 5 minutes or more? This will help me get a better understanding of the issue.
Additionally, it would be helpful if you could provide the game settings you are using so I can replicate your setup. Knowing which digital distribution service you are using to play the game will also assist in troubleshooting.
Please check if ReBAR is enabled in the BIOS. If you haven't already, could you try performing a clean installation using DDU and installing the latest graphics driver version 32.0.101.6460_101.6259.?
Lastly, make sure that in the Capture tab, the "Capture time" is set to 0 to remove the preset limit in capture time.
Dean R.
DeancR_Intel
Hi Kenzo-_-,
I'm following up to find out if you experience any issues. I'm not able to get any response from you regarding the needed information.
Dean R.
Kenzo-_-
It is the biggest vacation period in Korea
I will attach the data tomorrow.
DeancR_Intel
Hi Kenzo-_-,
I understand that it's the biggest vacation period in Korea, and I appreciate you letting me know. Please take your time and enjoy your break. I look forward to receiving the data. If there's anything else you need or if you have any questions in the meantime, feel free to reach out.
Dean R.
Kenzo-_-
Hi DeancR_Intel
Is this how you want to do it?
Please check the attached file.
In-game options are
Renderer : DirectX12
Mode : Windowed Fullscreen
Vsync : Adaptive
Window Resolution : 1920x1080
Upscale Mode : Intel XeSS
Image Quality : Performance or Balanced or Quality or Ultar Quality or Ultar Quality+
Texture Quality : Medium
Texture Filtering : 4x Antisotropic Filtering
Lighting : Shadows
Shadows Quality : Low
Sun Shadows Quality : Low
Number of Lights : Low
Water Detail Level : Low
Kenzo-_-
I've done more contents since the test
Endgame contents ↓
[Mechanics · Breach · Ritual · Delirium · Expedition · Trial of the Sekhemas · The Trial of Chaos · The Burning Monolith]
More Objects
More effects
In , the graphic card does not use its power.
The frame fell further
The frame is so bad that you can't enjoy the content.
Average 7~10 FPS
DeancR_Intel
Hi Kenzo-_-,
I appreciate your effort providing this information, let me check this further and get back to you once I have the necessary information.
Dean R.
Kenzo-_-
Hi DeancR_Intel
It's a character with a lot of objects and effects
I prepared the test results for the opposite character.
And unlike the specifications, graphics cards have low power consumption
I don't think the performance is working properly.
Please check it out
DeancR_Intel
Hi Kenzo-_-,
Thank you for sharing the game settings and CapFrameX data. However, it seems you forgot to mention where you are playing the game. Since Path of Exile 2 can be played on both Steam and Epic, could you please let me know which digital distribution service you are using? This will help us download it correctly.
Dean R.
Kenzo-_-
DeancR_Intel
Hi Kenzo-_-,
Thank you so much for providing all this detailed information. I really appreciate your effort. Let me check this further and I'll get back to you as soon as I have the necessary information.
Dean R.
DeancR_Intel
Hi Kenzo-_-,
I would like to inform you that I'm still investigating this internally for further checking about the issue.
Dean R.
Kenzo-_-
Hi
Okay
Soon, will I get an improved driver for poe2?
Kenzo-_-
The two-month patch history
There is no solution to this problem
Is it something you haven't solved?
Kenzo-_-
Does poe2 no longer improve performance with a graphics driver?
Recently deployed drivers still don't have performance improvement feedback for poe2
