Intel® Arc™ Discrete Graphics
4063 Discussions
Thermal pad Intel Arc A750
LC277G5xT
Hello everyone, I have a question, maybe you have the answer.
How thick are the thermal pads on the Arc A750?
if anyone has an answer that would be cool
Are they all the same thickness??
THANKS
Andres_Intel
Hello LC277G5xT,
Thank you for posting on the Intel communities. Please answer the following questions to have a better understanding related to the thickness of the thermal pad of your Intel® Arc™ A750 Graphics, I will be happy to help you.
  • Is the graphics card an Intel Branded Card or is it from another brand? This is to provide you with accurate information since the thermal pad may vary depending on the brand.
Andres P.
LC277G5xT
Oh sorry its a Arc A750 limited édition .
Andres_Intel
Hello LC277G5xT,
Thank you for your response and clarification.
Now I will start with an investigation and as soon I have the information I will let you know.
Andres P.
LC277G5xT
Andres_Intel
Hello LC277G5xT,
Thank you for your time and patience.
I have been working on the investigation, and I want to let you know generally you can find thermal pads of ~1mm thickness on the GPU.
Can I know what you are trying to achieve? Remember we do not support nor recommend opening the GPU itself and this can void its warranty.
Andres P.
Andres_Intel
Hello LC277G5xT,
Were you able to check that generally you can find thermal pads of ~1mm thickness on the GPU?
Andres P.
Andres_Intel
Hello LC277G5xT,
Andres P.
michaeel
The thermal pads on the Arc A750 are not all the same thickness. The thickness of the thermal pads, varies depending on the location of the pad on the card.
YannLR
there are two type : 1 mm for all application point. And 1.5 / 2 mm.
my card sitôt pads, help to make a choice please ?
picture two is the other. But which is which ?
bye ans nice day.
YannLR
Hi
after one atempt to fixe my card with pads 1.5 et 2 mm, it’s not stable and freeze.
only idle quiet température 50 celcius. In game it’s hot 90 celcius.
i bought 1 mm and see if the will ok to work safety and secure.
it’s very sad, Intel doesn’t inform consumer with s/n Number or other…
regards.
yann
