Intel® Arc™ Discrete Graphics
4046 Discussions
intel Arc A730M MXM card - HDMI signal does not resume from sleep
w0rn
This is an update from the previous support ticket (since it was closed)
Updating the drivers did not resolve the issue(s)
I believe that it is an issue with the A730m HDMI ports that do not 'wake from sleep' or they do not power back on after the computer enters sleep mode or hibernation.
I believe that a firmware (not driver!!) update is needed for the A730m card to address this
For reference, the A730M is a MXM add-in card for laptops. It looks similar to this
StanleyB_Intel
Hello W0rn,
Thank you for contacting Intel Community. I understand that the graphics driver update did not resolve the reported display glitches that occur after resuming from Windows sleep mode. I'll be conducting a further review with our team. Could you please confirm the details below, as this information will be valuable for our investigation:
  • When you updated the drivers for both Intel® UHD Graphics and Intel Arc A730M Graphics, did you use DDU (Display Driver Uninstaller) to remove any residual drivers?
  • You mentioned earlier that this behavior occurred with previous driver versions as well. Do you recall which specific versions those were, aside from the ones you've already mentioned?
  • Could you please provide us with another System Support Utility (SSU) report? This will help us compare it with the previous logs you've shared.
If you have any questions, please let us know.
Stanley B.
w0rn
Hi, to answer your questions:
Answer: yes, and I also downloaded (per the instructions from the previous topic/bug report) the most recent version of the intel graphics drivers.
Answer: from the screenshots it was driver 32.0.101.7029
Answer: see attachment.  I followed the instructions exactly as per the previous topic that I had made about this issue.  https://community.intel.com/t5/Intel-Arc-Discrete-Graphics/intel-Arc-A730M-glitches-when-trying-to-resume-from-windows/m-p/1742714
However, it seems there is a critical error/bug with the "Intel graphics software" app.  Either that, or intel does not frequently update the drivers for the Arc a730m BECAUSE the "intel graphics software" app says that my drivers are "up to date" (last scanned today) and yet the driver version was released back in 2023.  And this was AFTER I went through the clean uninstall instructions as per the previous topic, and reinstalled the most up to date drivers as per the instructions given in the previous topic.
I have provided additional screenshots about this problem with the intel graphics software
w0rn
Well today I downloaded Intel ARC graphics driver version: 32.0.101.872 and went through the install process again.  And Drivers are still stuck on the 2023 version.
I find it hard to believe that intel never released another driver or firmware update for the Arc a730m since 2023 so there is some other issue/glitch going on
w0rn
Today I tried to let windows find the most recent driver, and it said the driver from 2023 was the most recent.
Then I completely uninstalled EVERYTHING related to intel graphics/arc, and then ran the most recent driver package again. For some reason this time it installed the most recent driver (from april 2026). So now I am in a 'wait and see' mode to see if this driver actually does anything.
In the meantime I looked up other posts on the forum, and found several other topics about issues with waking up from sleep, or resuming from sleep etc.
for example:
https://community.intel.com/t5/Intel-Arc-Discrete-Graphics/Can-t-wake-monitor-after-going-to-sleep/m-p/1444033
and
https://community.intel.com/t5/Intel-Arc-Discrete-Graphics/Intel-ARC-380-will-not-wake-up-from-sleep/m-p/1461810#M2085
and
https://community.intel.com/t5/Intel-Arc-Discrete-Graphics/32-0-101-6732-Driver-bad-when-waking-up-from-sleep/m-p/1681112#M23356
and
https://community.intel.com/t5/Intel-Arc-Discrete-Graphics/Black-screen-bug-after-waking-pc-up-from-sleep-mode/m-p/1500795#M5622
and
https://community.intel.com/t5/Intel-Arc-Discrete-Graphics/Arc-770-wake-from-sleep-issues/m-p/1502970#M5840
SO APPARENTLY this is an issue that several people have had and have experienced
w0rn
Does intel have some kind of diagnostic or debug tool to run?  Even with the most recent driver (as of April 2026) the HDMI does not resume from sleep, or I get terrible glitching/artifacts on the screen when resuming from sleep.
StanleyB_Intel
Hello W0rn,
I appreciate your detailed responses regarding this ongoing topic, and thank you for updating me on your system's status when updating your Intel Arc A730M to the latest version (April 21st 2026). For accuracy, I'd like to confirm which exact version you're currently running to avoid any assumptions. Is your current driver version 32.0.101.8735?
Additionally, can you specify whether UHD graphics drivers were included in your update process. The current latest release is from March 18th 2026, designated as version 32.0.101.7085. Here's the download page for your convenience.
I understand that similar issues have been reported in other community discussions, and I realize how frustrating experiencing these artifacts can be, especially after updating your graphics driver. Let me suggest these steps that might help resolve this ongoing issue:
  1. Open Control Panel → Hardware and Sound → Device Manager
  2. Expand "Display Adapters," right-click your Intel Graphics entry, and select "Uninstall"
  3. In the confirmation dialog, check "Delete the driver software for this device" and click OK to begin uninstallation
  4. Once uninstallation completes, disconnect from the internet (ensure no auto-reconnect on restart) and reboot your system
  5. Extract the driver file to a designated folder
  6. Open Device Manager again
  7. Expand "Display adapters"
  8. Right-click the Intel® graphics entry (may appear as "Microsoft Basic Display Adapter") and select "Update Driver Software"
  9. Choose "Browse my computer for driver software"
  10. Click "Browse" and navigate to your extracted driver folder
  11. Click "Next" to install the drivers
  12. Restart when prompted
Alternate Method: Utilize Intel® Driver and Support Assistant for automated driver management.
  1. Type "Restore" in the Windows Start menu search
  2. Select "Create a Restore Point" from results
  3. Click "System Restore"
  4. Click "Next" on the initial screen
  5. Choose either "Recommended restore point" or "Choose a different restore point"
  6. Select an appropriate restore point from the available options
  7. Click "Next" to complete the process
While we don't currently offer a diagnostic tool specifically for integrated or discrete graphics cards, we do have the Intel® Processor Diagnostic Tool available for processor testing. However, there are third-party applications for graphics cards available that can provide this functionality.
Please let me know if you notice any new changes to your system.
Stanley B.
w0rn
Hi, the driver version is  32.0.101.8724 downloaded earlier this month.
I'll answer the other questions when I get to it, but I feel like the majority of the help/suggestions involves updating the driver...
But from all those old topics I found, this problem seems to have existed for a several years now.  So I have 0.001% hope anything will ever actually be done to fix this, nor will a driver update actually do anything either, since countless driver updates have been released in the YEARS since some of these topics were made.
Do these forums actually forward these issues to developers?
Being an issue that has  existed for years, seems like it should have been looked at by now.
Do the mods on this forum have any other actual solutions, other than suggestion a person updates the drivers?
StanleyB_Intel
Hello W0rn,
That is a fair observation, and I can imagine how disheartening it must be to keep hearing the same suggestion over and over. Let me try a different approach with you. Instead of jumping to standard solutions, can you help me and our team understand the following points below?
  • Did this function correctly previously, or has this issue existed from the beginning?
  • Have you attempted using the OEM driver version?
If you're willing, I'd recommend trying these straightforward steps:
  1. Make sure that Windows is updated.
  2. Check whether the correct driver is selected on the Device Manager
  • Go to Device Manager, > Display Adapters > Double Click Intel Arc A730M > Driver Tab > Update Driver > Browse my computer for drivers > Let me pick from a list of available drivers on my computer
  • Select the latest driver available from the options.
  • If there is only one option, proceed to update the driver from Intel® Arc™ Graphics,
  • Note: DO NOT perform a clean installation, but rather just do a simple installation without doing a clean installation.
I should also point out that developers are aware of these problems through our community forum, as this is a public venue where issues are visible.
Please don't hesitate to reach out if you have any additional questions or concerns.
Stanley B.
w0rn
Answer:  yes
Answer: no, because those OEM drivers were last updated 3 years ago.  So using woefully outdated drivers was never a solution in my mind.
Answer:  I am using windows 10 LTSC so there is no major OS update, just security patches. But yes, I install the monthly security updates from microsoft
  1. Check whether the correct driver is selected on the Device Manager etc etc etc
Answer:  Look, I tried all that and installing over existing ones, instead of a clean install. I also did the clean install. None of that helps or fixes the issue.  Again, it seems the 'help' is relegated to making sure the drivers are updated. Which is not a solution.
If the Intel developers read this forum as you say, and have been aware this issue has existed for 3 years (based on those old topics I found) and there has never been a solution or fix for this issue, then I have 0% hope it will ever be fixed, and frankly is rather disappointing - I would have been more than willing and happy to run a debug tool, and provide some kind of detailed report of how/why this keeps happening (but apparently no such tool exists, so how would the devs ever be able to diagnose this problem)
SeanD_Intel
Hello @w0rn,
Thank you for your continued patience and the comprehensive research you've conducted regarding this issue. I want to address your concerns about the OEM drivers and provide an update on the related cases you've identified.
I understand your hesitation about using 3-year-old OEM drivers, and your concern is completely valid from a security and feature perspective. However, I'd like to explain that OEM drivers might actually be more effective for your specific issue as OEM drivers are specifically modified and optimized for your exact hardware configuration including hardware-specific sleep/wake routines that coordinate with other system components
The threads you referenced affecting various Intel Arc models, I will look in to these threads internally and see what were the latest updates from these issues.
Allow me some time to look in to this, for now, I highly recommend using OEM provided drivers and firmware as these are best suited for your device. We will provide you with an update once available.
SeanD.
SeanD_Intel
Hello @w0rn,
Thank you for your patience as we reviewed your case. I want to provide you with an important clarification regarding support for your Intel Arc A730M MXM graphics.
Your Intel Arc A730M card falls under our embedded graphics category, which is specifically designed for embedded computer manufacturers (OEMs) and vendors creating fixed-function embedded devices such as ATM machines, cash registers, point-of-sale devices, in-vehicle infotainment systems, and similar embedded devices with displays.
Technical support for embedded graphics products is exclusively available for:
  • Embedded computer manufacturers
  • Vendors or distributors of Intel products through the Intel® Premier Support website
  • If you have access to Intel Premier Support, please submit your questions there.
  • If you're unsure about Premier Support access, please contact your Intel sales representative for assistance.
That said, I recommend that you contact your motherboard manufacturer, laptop manufacturer, or Intel Authorized Distributor.
For more information, you may review our public article Intel® Embedded Graphics Drivers Support.
Regarding the Community Threads you mentioned, I want to assure you that our team will be updating those threads, as fixes for these issues have already been released and are present in the latest Intel Arc Graphics drivers.
I understand this may not be the resolution you were hoping for, but this ensures you receive support from the team best equipped to assist with your specific hardware configuration and system integration.
This thread will now be closed and will no longer be monitored, if you have any other concerns, please feel free to create a new thread or post and we will be more than happy to assist you.
SeanD.
