Intel® Arc™ Discrete Graphics
4122 Discussions
latest drivers break Handbreak!
bo1983
Any driver after 101.6458_101.6257 makes Handbreak unusable. It takes forever to start and hardware encoding is no longer possible. 101.6458_101.6257 was the last working version! Intel, definitely fix it!
A770 16GB, DDU does not change the situation
# Starting Encode ...
[20:32:09] base preset: H.265 QSV 1080p
[20:32:09] Remote Process started with Process ID: 25052 using port: 8038. Max Allowed Instances: 3
[20:32:09] Worker: Starting HandBrake Engine ...
[20:32:09] Worker: Parent Process Id 8380
[20:32:09] Worker: Starting Web Server on port 8038 ...
[20:32:09] Worker: Starting Listener: 1
[20:32:09] Worker: Server Started
[20:32:10] Worker: Disconnected worker monitoring enabled!
[20:32:10] Compile-time hardening features are enabled
Cannot load nvEncodeAPI64.dll
[20:32:10] vcn: not available on this system
Wed Feb 12 20:32:13 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:gsc_driver_init():218) Error in HECI init (3)
Wed Feb 12 20:32:13 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:igsc_device_subsystem_ids():1597) Failed to init HECI driver
Wed Feb 12 20:32:16 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:gsc_driver_init():218) Error in HECI init (3)
Wed Feb 12 20:32:16 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:igsc_device_subsystem_ids():1597) Failed to init HECI driver
Wed Feb 12 20:32:19 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:gsc_driver_init():218) Error in HECI init (3)
Wed Feb 12 20:32:19 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:igsc_device_subsystem_ids():1597) Failed to init HECI driver
Wed Feb 12 20:32:22 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:gsc_driver_init():218) Error in HECI init (3)
Wed Feb 12 20:32:22 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:igsc_device_subsystem_ids():1597) Failed to init HECI driver
Wed Feb 12 20:32:25 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:gsc_driver_init():218) Error in HECI init (3)
Wed Feb 12 20:32:25 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:igsc_device_subsystem_ids():1597) Failed to init HECI driver
Wed Feb 12 20:32:28 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:gsc_driver_init():218) Error in HECI init (3)
Wed Feb 12 20:32:28 2025: IGSC: (D:\qb\workspace\31779\source\igsc-master\lib\igsc_lib.c:igsc_device_subsystem_ids():1597) Failed to init HECI driver
[20:32:30] Unable to start job. HandBrake was unable to communicate with the worker process. This may be getting blocked by security software. Try running without process isolation. See Tools Menu -> Preferences -> Advanced.
System.AggregateException: One or more errors occurred. (A task was canceled.)
---> System.Threading.Tasks.TaskCanceledException: A task was canceled.
at System.Threading.Tasks.Task.GetExceptions(Boolean includeTaskCanceledExceptions)
at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions)
at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
at System.Threading.Tasks.Task.Wait()
at HandBrakeWPF.Instance.RemoteInstance.RunEncodeInitProcess(JsonEncodeObject jobToStart)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state)
--- End of stack trace from previous location ---
--- End of inner exception stack trace ---
# Job Failed (4)
Earl_Intel
Hi bo1983,
We really regret any trouble and frustration this may have caused you, but don't worry—we'll look into the matter you raised and find a solution.
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Earl_Intel
Hi bo1983,
Earl E.
bo1983
# SSU Scan Information
Scan Info:
Version:"3.0.0.2"
Date:"02.18.2025"
Time:"00:00:29.9455781"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"ASUSTeK COMPUTER INC."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends Inc. 1805 , 10/30/2024"
CD or DVD:"HL-DT-ST BD-RE BH16NS55"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"13th Gen Intel(R) Core(TM) i9-13900K , GenuineIntel"
Secure Boot State:"On"
SMBIOS Version:"3.5"
Sound Card:"USB-Audiogerät"
Sound Card:"Sound BlasterX AE-5 Plus"
System Manufacturer:"ASUS"
System Model:"System Product Name"
System SKU:"SKU"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "Intel(R) Arc(TM) A770 Graphics"
Adapter Compatibility:"Intel Corporation"
Adapter DAC Type:"Internal"
Adapter RAM:"2,00 GB"
Bits Per Pixel:"32"
- "Caption":"Intel(R) Arc(TM) A770 Graphics"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=Arc+A770+Graphics"
CoInstallers:"oem180.inf,DG2_Client_FWU_wNext,Internal,Intel(R) Arc(TM) A770 Graphics Family"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"igdkmdnd64.sys"
Driver Date:"02.04.2025 01:00"
Driver Path:"C:\Windows\system32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4710909d97091293\igdkmdnd64.sys"
Driver Provider:"Intel Corporation"
Driver Version:"32.0.101.6559"
INF:"oem180.inf"
INF Section:"DG2_Client_FWU_wNext"
Install Date:"Not Available"
Installed Drivers:"C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4710909d97091293\igdumdim64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4710909d97091293\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4710909d97091293\igd10iumd64.dll,C:\Windows\System32\DriverStore\FileRepository\iigd_dch_d.inf_amd64_4710909d97091293\igd12umd64.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"Intel Corporation"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_8086&DEV_56A0&SUBSYS_10208086&REV_08\6&DB525E3&0&00080008"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"60 Hz"
Refresh Rate - Maximum:"75 Hz"
Refresh Rate - Minimum:"23 Hz"
Resolution:"3840 X 2160"
Scan Mode:"Noninterlaced"
Service Name:"igfxnd"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"Intel(R) Arc(TM) A770 Graphics Family"
- "Memory"
Physical Memory (Available):"21,75 GB"
Physical Memory (Installed):"64 GB"
Physical Memory (Total):"63,75 GB"
- "BANK 0"
Capacity:"32 GB"
Channel:"Controller0-DIMM1"
Configured Clock Speed:"6000 MHz"
Configured Voltage:"1100 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First position"
Manufacturer:"Kingston"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"KF556C40-32"
Serial Number:
Status:"Not Available"
Type:"Synchronous"
- "BANK 0"
Capacity:"32 GB"
Channel:"Controller1-DIMM1"
Form Factor:"DIMM"
Interleave Position:"Second position"
Serial Number:
Type:"Synchronous"
- "Motherboard"
BIOS:"1805, ALASKA - 1072009"
Caption:"Hauptplatine"
Chipset:"Not Available"
Date:"10.30.2024 01:00"
Model:"Not Available"
Part Number:"Not Available"
PNP Device ID:"Not Available"
Product:"PRIME Z790-A WIFI"
Serial Number:
Status:"OK"
Version:"Rev 1.xx"
- "Operating System"
.Net Framework Version:"2.0,3.0,3.5,4.0,4.8"
Boot Device:"\Device\HarddiskVolume1"
Internet Browser:"Google Chrome,133.0, Internet Explorer,11.1882, Microsoft Edge,133.0, Vivaldi, Not Available"
Locale:"Deutschland"
OS Manufacturer:"Microsoft Corporation"
OS Name:"Microsoft Windows 11 Enterprise"
Other OS Description:"Not Available"
Page File:"C:\pagefile.sys"
Page File Space:"64,00 GB"
System Directory:"C:\Windows\system32"
Version:"10.0.26100 Build 26100"
Virtual Memory (Available):"76,64 GB"
Virtual Memory (Total):"127,75 GB"
Windows Directory:"C:\Windows"
- "Installed Updates"
KB2151757:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [08.12.2024]"
KB2467173:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [08.12.2024]"
KB2468871:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2468871v2:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2478063:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2533523:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2544514:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600211:"Microsoft .NET Framework 4 Extended [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Client Profile [Not Available]"
KB2600217:"Microsoft .NET Framework 4 Extended [Not Available]"
KB5048779:"Update [12/7/2024]"
KB5050577:"Update [1/30/2025]"
KB5051987:"Security Update [2/12/2025]"
KB5052085:"Security Update [2/12/2025]"
KB982573:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [08.12.2024]"
Microsoft ASP.NET Core 6.0.36 - Shared Framework (x86):".NET [09.12.2024]"
SP1:"Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 [Not Available]"
- "Processor"
- "13th Gen Intel(R) Core(TM) i9-13900K"
Architecture:"x64"
ATPO:"Not Available"
Caption:"Intel64 Family 6 Model 183 Stepping 1"
- "Chipset Name":"13th Gen Intel(R) Core(TM) i9-13900K"
Link:"http://www.intel.com/content/www/us/en/search.html?keyword=13th+Gen++Core+i9+13900K"
CPU Speed:"3 GHz"
Current Voltage:"9. volts"
Driver:"Not Available"
Driver Date:"04.21.2009 12:00"
Driver Path:"C:\Windows\system32\drivers\intelppm.sys"
Driver Provider:"Microsoft"
Driver Version:"10.0.26100.3037"
Ext. Family:"Not Available"
FPO:"Not Available"
INF:"cpu.inf"
INF Section:"IntelPPM_Inst.NT"
Level 1 Cache:"24 x 384 KB"
Level 2 Cache:"24 x 32768 KB"
Level 3 Cache:"36 MB"
Load:"2%"
Manufacturer:"GenuineIntel"
Model:"183"
Name:"13th Gen Intel(R) Core(TM) i9-13900K"
Number of Cores:"24"
Number of Cores Enabled:"24"
Number of Logical Processors:"32"
Part Number:"To Be Filled By O.E.M."
Power Management Supported:"No"
Processor ID:"BFEBFBFF000B0671"
Revision:"Not Available"
Serial Number:"To Be Filled By O.E.M."
Service Name:"intelppm"
Status:"OK"
Stepping:"1"
...#SSU#...
Earl_Intel
Hi bo1983,
Earl E.
bo1983
Scan Info:
Version:"3.0.0.2"
Date:"02.21.2025"
Time:"00:00:31.6734513"
# Scanned Hardware
Computer:
BIOS Mode:"UEFI"
System SKU:"SKU"
- "Display"
Bits Per Pixel:"32"
INF:"oem180.inf"
Monochrome:"No"
Status:"OK"
- "Memory"
Physical Memory (Available):"20,74 GB"
- "BANK 0"
Capacity:"32 GB"
Form Factor:"DIMM"
Serial Number:
Type:"Synchronous"
- "BANK 0"
Capacity:"32 GB"
Form Factor:"DIMM"
Serial Number:
Type:"Synchronous"
- "Motherboard"
Serial Number:
Status:"OK"
Version:"Rev 1.xx"
Internet Browser:"Google Chrome,133.0, Internet Explorer,11.1882, Microsoft Edge,133.0, Not Available, Vivaldi"
Physical Memory (Available):"20,79 GB"
Virtual Memory (Available):"77,14 GB"
- "Processor"
Architecture:"x64"
CPU Speed:"3 GHz"
FPO:"Not Available"
INF:"cpu.inf"
Load:"5%"
Model:"183"
Status:"OK"
Stepping:"1"
...#SSU#...
bo1983
Scan Info:
Version:"3.0.0.2"
Date:"02.21.2025"
# Scanned Hardware
Computer:
BIOS Mode:"UEFI"
System SKU:"SKU"
- "Display"
Bits Per Pixel:"32"
INF:"oem180.inf"
Monochrome:"No"
Status:"OK"
- "Memory"
- "BANK 0"
Capacity:"32 GB"
Form Factor:"DIMM"
Serial Number:
Type:"Synchronous"
- "BANK 0"
Capacity:"32 GB"
Form Factor:"DIMM"
Serial Number:
Type:"Synchronous"
- "Motherboard"
Serial Number:
Status:"OK"
Version:"Rev 1.xx"
- "Processor"
Architecture:"x64"
CPU Speed:"3 GHz"
FPO:"Not Available"
INF:"cpu.inf"
Load:"5%"
Model:"183"
Status:"OK"
Stepping:"1"
...#SSU#...
bo1983
here the log
Earl_Intel
Hello bo1983,
Thank you for providing us the SSU logs.
No worries, I'll further review the logs that you provided a will check this internally.
I'll provide you an update on this thread as soon as possible.
Earl E.
bo1983
latest driver fixed all bugs, thx
DeancR_Intel
Hello bo1983,
I'm glad the issue was resolved on your end. Let me know if I can close the thread.
Dean R.
bo1983
hi dean,
thread can be closed at this point
Earl_Intel
Hello bo1983,
Thank you for the confirmation.
I will now close this thread, if you need further assistance, please submit a new question as this thread will no longer be monitored.
Earl E.
