Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
AMT KVM w boot option iommu=on
fsmsolutions
Hi, All
I use Ubuntu 13.10 (kernel 3.11.0 amd64) server running on dq67sw.
When I connect via VNC AMT,  appears  flashing icon in the upper right corner of the server screen.
When server loaded with the boot option iommu=on
each accompanied by a flashing icon output to console:
Nov 28 07:40:41 dq67srv kernel: [ 9238.777273] dmar: DRHD: handling fault status reg 2
Nov 28 07:40:41 dq67srv kernel: [ 9238.777316] dmar: DMAR:[DMA Read] Request device [00:02.0] fault addr 2b7024d000
Nov 28 07:40:41 dq67srv kernel: [ 9238.777316] DMAR:[fault reason 07] Next page table ptr is invalid
Nov 28 07:40:41 dq67srv kernel: [ 9238.777901] dmar: DRHD: handling fault status reg 3
Nov 28 07:40:41 dq67srv kernel: [ 9238.777942] dmar: DMAR:[DMA Read] Request device [00:02.0] fault addr 2b7024d000
Nov 28 07:40:41 dq67srv kernel: [ 9238.777942] DMAR:[fault reason 07] Next page table ptr is invalid
Nov 28 07:40:41 dq67srv kernel: [ 9238.778029] dmar: DRHD: handling fault status reg 2
Nov 28 07:40:41 dq67srv kernel: [ 9238.778063] dmar: DMAR:[DMA Read] Request device [00:02.0] fault addr 2b7024d000
Nov 28 07:40:41 dq67srv kernel: [ 9238.778063] DMAR:[fault reason 07] Next page table ptr is invalid
Nov 28 07:40:41 dq67srv kernel: [ 9238.778341] dmar: DRHD: handling fault status reg 3
[bash]user@dq67srv:~$ lspci |grep 00:02.0
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
[/bash]
Which makes it impossible to work through VNC.
  1. How to suppress the flashing iconn
  2. Why is this problem:
  •   - Linux kernel
  •   - Igfx driver
  •   - ME firmware?
Thx,
Maxim
Gael_H_Intel
Sounds like a Sandy Bridge system - AMT 7 - correct?  What is the configuration of your AMT Client?  FW version, AMT SDK verson and which tools are you using to connect to the KVM?
fsmsolutions
My system:
Baseboard
Manufacturer
Intel Corporation
Product name
DQ67SW
Version
AAG12527-305
Serial number
BQSW110001WR
BIOS
Vendor
Intel Corp.
Version
SWQ6710H.86A.0066.2012.1105.1504
Release date
11/05/2012
 Processor 1
Manufacturer
Intel(R) Corp.
Family
Intel® Core™ i7 Processor
Socket
SKTH
Version
Intel(R) Core(TM) i7-2600 CPU @ 3.40GHz
ID
13829424153406604967
VNC client: RealVNC VNC Viewer Plus 1.2.6(r113854)
ojw_nc
Did you ever find a solution to this?
