Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
CPUID
Peter_Z_
When working on an test machine running Windows Server on a cloud we run a Windows application.
It uses WMI (Windows Management Information)'s Processor class to query how many processors there are.
There are 2: both Xeon 14 core 2.6 GHz. But the CPU IDs are equal: F106 0400 FFFB EBBF. It does not matter  to our app but we thought CPU ID
was unique at least on our planet.
gaston-hillar
Valued Contributor I
Hi Peter,
You can check the following link with information about the information provided by the CPUID instruction. The same CPU models will return the same values.
gaston-hillar
Hi Peter,
You can download the Intel® Processor Identification Utility and check the results to understand what CPUID provides for each CPU.
gaston-hillar
Hi Peter,
Did the info I provided help you to understand what CPUID provides for each CPU?
Asher__Eli
I'm trying to use the Intel Media SDK for Windows -> mediasdk-tutorials-0.0.4 -> simple_3_encode_vmem_async.(project: simple_encode_d3d_async) and after the compilation process I got the following error:
C3861  '__cpuid': identifier not found (common_utils.cpp  line:466)
Please your help, thanks!
Eli
Asher__Eli
I downloaded the Intel® Media SDK for Windows ---> simple_3_encode_vmem_async ---> simple_encode_d3d_async, the compilation process is done but when I run the application - in file crt0dat.c (line:774) - when application calls to function ExitProcess(status) - the application was exit with error number 0.
Please your help how to resolve this problem.
Thanks!
Eli
Asher__Eli
I downloaded the software package of Intel® Media SDK for Windows ---> simple_3_encode_vmem_async ---> simple_encode_d3d_async, the compilation process is done but when I run the application - in file crt0dat.c (line:774) - when application calls to function ExitProcess(status) - the application was exit with error number 0.
Thanks!
Eli
Asher__Eli
Thanks!
Eli
