I am unable to connect to AMT via web browser, PSM and Meshcommander over an OpenVPN connection. This is happening at 3 different sites.
If done locally I have no problem, so I can confirm that vPRO is enabled. These are SMB sites so the devices are provisioned manually (CTRL-P).
Is this a known or "by design" issue?
Hey David
The easiest VPN solution that will work is a site to site VPN.
If you are wanting VPN to the client, That is a lot more complex model. Take a look here to get started -
Joe
Hey David
Joe
Thanks. That should help.
			Topic Options
