Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
DC7700
descargar2
English (Google Translation)
Hello, since upgraded the bios to boot the PC, I get this error
ME BIOS Extension module execution has halted. Management Engine Update BIOS or firmware if problem persists.
Searching the google I found a post referred to this problem
software.intel.com/en-us/forums//topic/54262
I tried to follow what he says "FWUpdLcl.exe-run with the switch FWUpdLcl.exe-generic-generic" but when I run this command gives me the error
X:swsetupSP36847ME FlashLocal-Win>FWUpdLcl.exe -generic
Error: Failed to open image file -generic
Error: Failed to parse image file
Question 2: Where can I find the driver my motherboard? I have an HP Compaq dc7700 Convertible Minitower PC
Spanish (Recommended)
Hola ,desde que actualize la bios al arrancar el PC me sale el error.
ME BIOS Extension module execution has halted. Update BIOS or Management Engine firmware if problem persists.
Buscando el google he encontrado un post referido a este problema
He intentado seguir lo que dice "-run FWUpdLcl.exe with the -generic switch FWUpdLcl.exe -generic" pero cuando ejecuto ese comando me da el error
2 Pregunta:Donde puedo encontrar los driver de mi placa base ? Tengo un HP Compaq dc7700 Convertible Minitower PC
Sreelekshm_S_Intel
Did you copy 213_1031.BIN to the ME Flashlocal-win folder?
You should run the command as FWUpdLcl.exe -generic in the ME Flashlocal-win folder.
You need to download your drivers from HP site http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3232101〈=en&cc=us&prodTypeId=12454&prodSeriesId=3232028&taskId=135
Sree
descargar2
ENGLISH:
Hello, What all this is the list of drivers on the motherboard?
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3232101&prodTypeId=12454&prodSeriesId=3232028&swLang=13&taskId=135&swEnvOID=1093
BIOS: In the "symbol of the" I or cmd.exe
cd C:swsetupSP36847ME FlashLocal-Win
And error
C:swsetupSP36847ME FlashLocal-Win>FWUpdLcl.exe -generic
SPANISH (RECOMMEND)
Hola, cual de toda la lista son los driver de la placa base
BIOS: En el "simbolo de sistema" o cmd.exe pongo
Yerror
221_1034.BIN or 213_1031.BIN
I found only 221_1034.BIN, spanish solo he encontrado 221_1034.BIN
Sreelekshm_S_Intel
You need to run
FWUpdLcl.exe 221_1034.BIN -generic
shows all the drivers for dc7700 system; you need to install only the required ones. To upgrade the AMT firmware, you need to have LMS and HECI installed.
Sree
descargar2
ENGLISH (Google Translations)
Ok, Thank you already fixed the error of the bios
When you start your PC, I get this.
Spanish:
Muchas gracias ya esta solucionado el error de la bios
http://s1.subirimagenes.com/imagenes/previo/thump_1944884Dibujo.jpg
Al arrancar el PC me aparece esto
http://s1.subirimagenes.com/imagenes/previo/thump_1944903Dibujo2.jpg
Sreelekshm_S_Intel
The firmware upgrades, HECI and LMS should be downloaded from the OEM site. The driver site above, http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3232101&prodTypeId=12454&prodSeriesId=3232028&swLang=13&taskId=135&swEnvOID=1093
includes HECI and LMS downloads. Also, i found a similar issue here - http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1105560
You might want to try this.
Sree
descargar2
While you were answering me I was editing ..
http://software.intel.com/en-us/forums/showthread.php?t=57650#55267
And driver the Motherboard?
Gael_H_Intel
Hi - I think you may actually be at a stage where you can now provision your system. You got the AMT Status message which tells us that your bios/firmware is loaded correctly. You will still need to get the HECI and LMS drivers installed if you want to make calls to AMT locally (from the AMT client itself.) But you should be able to quickly see if you can provision the system in Small Business Mode and then see if you can connect to it via the WebUI from your management console system.
Sree has given you the link to where the rest of the drivers are - let us know how it is going.
