Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Error in provisioning an iAMT device
peri
I am trying to provision the iAMT 2.0 device using the SCA that comes with Intel_R__AMT_SDK_Release_5.1.1. I see the following error messages in the SCA console.
Waiting for incoming connection...
[2010-01-04 11:48:26] Incoming Connection from 164.99.96.49:16994
Incoming data is:
Configuration version: PSK Configuration
Count : 2
UUID : 20C305E8-AC0D-DC11-A7CD-000EA68F7399
PID : 0000-000C
reading configuration from default.conf.xml
>> starting soap call sequence <<
Error: failed while calling GetCoreVersion
Res = 401
Error 401 fault: SOAP-ENV:Server [no subcode]
"HTTP Error"
Detail: HTTP/1.1 401 Unauthorized
- failed to establish connection with AMT
- attempt to connect using default credentials...
Res = 401
"HTTP Error"
Aborting configuration
Warning: SetProvisioningParameters() failed
But i set the cfg_username to admin and cfg_password set to MEBx password. Could you please let me know what causes this error?
Periyasamy
peri
Discard this post.
i was trying with an incorrect default.conf.xml :)
Quoting - pperiyasamy
Incoming data is:
Count : 2
PID : 0000-000C
Res = 401
"HTTP Error"
Res = 401
"HTTP Error"
Periyasamy
