Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
Intel Manageability Commander remote desktop can't work thinkcenter m8500t
chen_d_
[Host Information]
Item    Value
Operating System Name    Microsoft Windows 7 profession
Operating System Version    6.1.7601 Service Pack 1 Build 7601
System Manufacturer    LENOVO
System Name   aa
System Model    ThinkCentre M8500t-N085
Processor    Intel(R) Core(TM) i7-4790 CPU @ 3.60GHz, 3.60 GHz, 4 Core(s), 8 Logical Processor(s)
BIOS Version    LENOVOFBKTC6AUS
LAN DeviceID    PCI\VEN_8086&DEV_153A&SUBSYS_309717AA&REV_04\3&11583659&0&C8
LAN Driver    12.6.47.0
WLAN DeviceID    NA
WLAN Driver    NA
[Intel(R) ME Information]
Item    Value
ME Control Mode    Admin
Provisioning Mode    Post Provisioning
BIOS boot    Post Boot
Last ME reset reason    Power Up
System UUID    24854298-8347-11e6-8610-3a070ace1c00
Local FWUpdate    Enabled
Power Policy    Desktop: ON in S0, ME Wake in S3, S4-5
Cryptography Support    Enabled
[FW Capabilities]
Item    Value
Intel(R) Active Management Technology    Enabled
Intel(R) Anti-Theft Technology PC Protection    Enabled
Intel(R) Capability Licensing Service    Enabled
Intel(R) Dynamic Application Loader    Enabled
Protect Audio Video Path    Enabled
[Intel(R) Active Management Technology]
Item    Value
Intel(R) AMT State    Enabled
Intel(R) AMT Status    Configured
CIRA Connection Status    Not Connected
[Intel(R) Anti-Theft Technology PC Protection]
Item    Value
Intel(R) AT State    Enabled
Intel(R) AT Status    Not Enrolled
[Components Information]
Item    Value
MEBx Version    10.0.0.0007
FW Version    9.1.30.1008
LMS Version    11.0.0.1183
MEI Driver Version    11.0.0.1181
MEI DeviceID    PCI\VEN_8086&DEV_8C3A&SUBSYS_309717AA&REV_04\3&11583659&0&B0
SOL Driver Version    11.0.0.1136
SOL DeviceID    PCI\VEN_8086&DEV_8C3D&SUBSYS_309717AA&REV_04\3&11583659&0&B3
[Network information]
Item    Value
LAN MAC Address    6C:0B:84:DE:7F:D0
LAN Configuration state    Static
LAN Link Status    Link Up
LAN IPv4 Address   192.168.1.100
LAN IPv6 Enablement    Disabled
WLAN MAC Address    NA
WLAN Configuration state    NA
WLAN Link Status    NA
WLAN IPv4 Address    NA
WLAN IPv6 Enablement    NA
I can use the Intel Manageabilty  commanger(version 1.08) connect the computer ,see the system status, hardware infomation ,event log ,audit log...
I also can use IE address  http://192.168.1.100:16992  access the computer,remote control reset or shutdown the computer.
when I use the  Intel Manageabilty  commanger Remote Desktop section, clike Connect buttion, but it don't work without showing anything.
Joseph_O_Intel1
Hello Chen,
If you are having issues with KVM connecting, it is usually an issue in that the device has KVM disabled. If the Intel Manageability Commander is being used, there should be a warning message above the KVM window, just click on that message and make sure that the redirection port and KVM boxes are both  checked at a minimum.
Joe
chen_d_
Hello Joseph,
I have already checked the Redirection Port and KVM Remote Desktop boxes.
When i click then Remote Desktop Connect button ,the Connect button status can change Disconnect ,but few second late change Connect.
Remote Desktop don't work.
Click Serial-over-Lan Connect button,the Connect button status can change Disconnect,but all function can't work.
Joseph_O_Intel1
Hey Chen,
I would suggest download the SCS configurator package. Then run  "acuconfig.exe systemdiscovery" from the command line after navigating to the folder containing acuconfig.exe
This will generate an xml file in that folder. In that XML is a <amtsku> tag, what is that value?
There are also three KVM related xml tags, what values do they hold? All three need to be true in order for KVM to work.
Joe
chen_d_
Hello Joseph,
<AMTSKU>Intel(R) Full AMT Manageability</AMTSKU>
  <AMTversion>9.1.30</AMTversion>
  <FWVersion>9.1.30.1008</FWVersion>
  <AMTSKUNumber>2</AMTSKUNumber>
  <PingConfigurationServer>False</PingConfigurationServer>
- <KVMOptions>
  <EnableKVM>True</EnableKVM>
  <EnableUserConsent>True</EnableUserConsent>
  <UserConsentTimeout>300</UserConsentTimeout>
  </KVMOptions>
Joseph_O_Intel1
Hey Chen
Can you please send me a PM with the complete xml file to me please
Joe
GRile
I believe I have the same problem, did you ever solve it?  I have opened a support ticket for this.
Does anyone know what I can do to troubleshoot this? Are there any logs either on the target host or the client running the Commander that I can check?
Regards, Graham
Joseph_O_Intel1
Hey Graham
Does your think center have Discrete Video card or does not have a monitor attached?
Joe
