Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
PRTC timer
Terence_C_Intel
do iAMT provideAPI for ISV that can modify the PRTC timer remotely? Thanks
Gael_H_Intel
The Intel AMT SCS Installation and User Manual provides some guidance on setting the PRTC timer. (You will need to download the SCS 1.1 release from the Manageability Developer Community website.) SCS=Setup and configuration Server.
--GTH
Gael_H_Intel
Hello, I am also told that you can findit in the Network Interface Guide under Network Time Interface (see SetHighAccuracyTimeSynch and GetLowAccuracyTimeSynch).
--GTH
Terence_C_Intel
thanks. this is helpful.
Terence_C_Intel
Theconsolecan set and getthe time throguht Network Time Interface. How about the local agent? how localagent toget thePRTC time? the agent need to read the iAMT event log timestamp clock. Thanks
Gael_H_Intel
You can only get and set the time remotely. Note that in the Network Inerface Guide, each interface lists the "Default Interface Access Permissions" followed by a box that specifies Local Access and Network Access Permissions. The Network Time Interface specifies that Local Access is not allowed.
GTH
vzvezda
Is it possible to change somehow the "Default Interface Access Permissions"?
Gael_H_Intel
The Interface Access Permissions cannot be changed. (I agree, having the term "Default" does kind of imply that they can be modified.)
