- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Version AMT is 5.0.1
SKU is 18494(0x483E)
How I udestand documentation 0x483E=iQST + TPM + ASF + Intel AMT Pro + Intel Standard Manageability.
And this configurationsupported by Intel AMT Pro SKU.
When I call functions GeneralInfoService.GetAuditPolicy or GeneralInfoService.GetAuditLogStatus I got error N 2066(The requested configuration is unsupported). Why I got this error?
Lien copié
7 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Quoting - gennadiy
Hi gennadiy,
Can you tell us what CPU ID your system is running? I'm looking for a number that looks like: E4700 or a Processor name that looks something like: "Intel Core2Duo E4000 Series."
It looks like your system is equipped with an upgradeable CPU (Standard Manageability (5.0)has the same features as Intel AMT 3.2 (no Audit Log)) - this CPU can be upgraded to Intel AMT 5.0. Has this system been upgraded to 5.0?
Gael
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Quoting - Gael Holmes (Intel)
Hi gennadiy,
Gael
This is information about my CPU
ID: 7A 06 01 00 FF FB EB BF
Version: Intel Core2 Duo CPU E7400 @ 2.80GHz
Where I can get upgrade forAMT 5.0 and where is tools for upgrading?
Gennadiy.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi gennadiy,
Gael
Hi Again,
I am curious - where did you get this system? It was my understanding that our OEMs were not selling these upgradeable systems yet... Are you an Intel Reseller?
I will get back to you regarding your other question soon.
Gael
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Again,
Gael
I have bought system in Ukraine. I am not Intel Reseller.
Gennadiy.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Quoting - gennadiy
Hi Gael,
Gennadiy.
Hi Gennadiy,
I have found out that we can only do upgrades in the US and Canada at this time. Your system as it ishas the full AMT 3.2 feature set. The Start Here Guide has a list of features for each version of Intel AMT (the full listing of features from earlier versions are listed in an appendix.)I'm also attaching the versions.txt file out of the SDK - it also shows all the AMT versions and their differences.
If you were really hoping to have a full AMT 5.0 feature set, you may want to talk to your distributor and see if there is anything you can do regarding getting a CPU that supports AMT 5.0 (The 8400 CPUs and higher support the full AMT 5.0 capability and you must have the Q45 Chipset, which your system should have.) Here is a linkthat has a pretty good list of vPro systems (the ones that do not require upgrading.)
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Quoting - gennadiy
Hi Gael,
Gennadiy.
Hi Gennadiy,
If you were really hoping to have a full AMT 5.0 feature set, you may want to talk to your distributor and see if there is anything you can do regarding getting a CPU that supports AMT 5.0 You must have the Q45 Chipset, which your system should have. Here is a linkthat has a pretty good list of vPro systems (the ones that do not require upgrading.)
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Gennadiy,
Thank you for your help. I will upgrade my system to full AMT 5.0.
Gennadiy.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
