Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
1412 Discussions
What features should I look for to confirm it is NOT a vPro?
lentsoe_m_
Hi All
I would like to know what features should I look for in order to confirm this is NOT a vPro capable. Should I look at an AMT or ME Firmware version in order to confirm it is NOT a vPro?
Basically I would like to know how do I tell even if there is a sticker that said vPro, but how do I tell that is NOT a vPro.
Can I use Intel® Setup and Configuration Software to determine features that confirm it is NOT a vPro?
I will really appreciate your response on this matter.
Lezwi
Joseph_O_Intel1
Greetings Lentsoe
Yes you can use SCS tools to determine if a device is not a vPro device, simply do the following:
  1. Is the system XEON. i5, i7 Core M then do go to step 2
  2. Perform a "System Discovery" by downloading the Intel SCS Configurator Tools
  3. Then from the command line run the following from the configurator folder within the download: acuconfig systemdiscover
  4. This will create a <FQDN>.xml file
  5. Inspect the file for the <AMTSKU> feild if it doen not say Full Active Management Technology, then it is not a vPro device.
