Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
WsMan Asset Vs. EOI Asset
jacace
Hello everybody,
I have been looking into the differencies between the EOI and the WsMan asset.
I have seen that the following functions does not get all the information:
arrTmp=client.Enumerate(typeof(CIM_ProcessorType));
arrTmp = client.Enumerate(typeof(CIM_PhysicalMemoryType));
arrTmp = client.Enumerate(typeof(CIM_MediaAccessDeviceType));
arrTmp=client.Enumerate(typeof(AMT_PCIDeviceType));
The thing is that the above MOF classes(CIM_XXX, AMT_XXX)are the ones used to deserialize the WsMan commands, so after Enumerating them and call the respective Intel AMT stack object constructor I can see not all the information is loaded; I mean, if I compare WsManconstructed objectagain the corresponding EOI object (GetAssetOfType(AmtHardwareModule.XXX)) not all the information is present.
So, wha's wrong?
Thanks a lot,
Javier Andrs Cceres Alvis
Randal_T_Intel
This is a known bug in the WsMan implementation of the Asset interface. You're not doing anything wrong
jacace
Any suggestion?
Thanks a lot,
Lance_A_Intel
Hi Javier, we are seeking assistance from our WS-Man expert on this one. Hope to get back to you soon.
jacace
Thanks a lot Lance!
Randal_T_Intel
jacace
Thanks a lot Randal,
jacace
Hello Randal,
I have a question: I understand this issue is about theWsMan implementation on machine (I mean, I supose there is a bug on code running at the amt machine side); my AMT version is 3.2.1, What do you knowabout AMT 4, 5 versions?
I have more feedback: this also affects Redirection cause power state is found by WsMan as "S2_SLEEPING_WITHOUT_CONTEXT" and by EOI is correctly read as "SO_POWERED". (see this thread: http://software.intel.com/en-us/forums/showthread.php?t=61463)
Thanks a lot,
Randal_T_Intel
Thanks for the feedback. The WsMan asset issue appears to be limited to 3.x firmware.The SDK asset sample should work on AT4/5 hardware
jacace
Thanks Randal
