Intel® Business Client Software Development
Support for Intel® vPro™ software development and technologies associated with Intel vPro platforms.
how to disable amt technologie in remote pc
karimmass
I just installed many pc (HP dc7900) for clients, these PCs have default AMT technology Enabled, I want to know how I could disable remotly this technology on the PC that I have remote access to the OS of these machine
I know how well off this technology on a PC with the CTRL + p view that I am a HP technical , but I do not know how the disabled on a remote machine, is that it is possible to disable AMT dirctement under the OS for example by disabling all services AMT
Andrew_S_Intel2
Quoting - karimmass
I didn't think any OEM's shipped a vPro system with AMT enabled,the normal model is that the enduser needs to provision (enable) AMT. Mainly for the reason you mention, so endusers can choose to enable AMT.Maybe I'm misunderstanding what you mean by you want to disable AMT, can you currently use AMT? An HP 7900c is an AMT 5.0 machine I believe, so it should have Intel Management and Security Status program. If you bring up the Intel Management and Security Status program, and go into the Intel AMT tab, what shows up for the Status under Intel AMT State? Mainly I want to make sure what you are trying to accomplish.
Do you mean you want to disable the ability to provision AMT? That can be done, but generally only through the BIOS.
