Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Docker error in start services
ANIL_K_3
After success build docker containers both with source and with out , starting image and entering into bash was good , when starting services in build and run both containers giving following error in cluster node start
021-04-22 07:06:19.326 - WARN: AmqpClient - Connecting error: { Error: connect ECONNREFUSED 127.0.0.1:5672
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
cause:
errno: 'ECONNREFUSED',
code: 'ECONNREFUSED',
syscall: 'connect',
address: '127.0.0.1',
port: 5672 },
Cluster node log :
2021-04-22 14:35:43.701 - INFO: ClusterManager - Run as slave.
2021-04-22 14:35:43.701 - INFO: ClusterManager - Someone else became master.
2021-04-22 14:35:43.703 - INFO: ClusterManager - Cluster manager is in service as master!
2021-04-22 14:35:43.704 - INFO: ClusterManager - Cluster manager is in service as master!
2021-04-22 14:35:43.706 - INFO: ClusterManager - Cluster manager is in service as master!
2021-04-22 14:35:43.708 - INFO: ClusterManager - Cluster manager is in service as master!
2021-04-22 14:35:43.722 - INFO: ClusterManager - Lose heart-beat from master.
2021-04-22 14:35:43.722 - INFO: ClusterManager - Run as candidate.
2021-04-22 14:35:43.729 - ERROR: ClusterManager - !!Double master!! self: 144145397 another: 969215517
2021-04-22 14:35:43.729 - ERROR: ClusterManager - Another master is more senior than me, I quit.
2021-04-22 14:35:43.729 - WARN: Main - Exiting on SIGINT
2021-04-22 14:35:45.970 - INFO: Main - Process exit
ANIL_K_3
any solution ?
