hi! please help!
bin/start-all.sh
	starting nuve, stdout -> /home/jin/Desktop/MCU_Release-v2.1.1/logs/woogeen-nuve.stdout
	1476
	1484
	2015-06-29 11:27:15.122  - INFO: RPC - Conected to rabbitMQ server
	2015-06-29 11:27:15.124  - INFO: RPC - Exchange rpcExchange is open
	2015-06-29 11:27:15.127  - INFO: RPC - Queue nuveQueue is open
	2015-06-29 11:27:15.128  - INFO: RPC - ClientQueue amq.gen-DRGzdiYVxIVM-gARtwBCNQ is open
	starting mcu, stdout -> /home/jin/Desktop/MCU_Release-v2.1.1/logs/woogeen-mcu.stdout
	2015-06-29 11:27:20.877  - INFO: RPC - Exchange rpcExchange is open
	2015-06-29 11:27:20.882  - INFO: RPC - ClientQueue amq.gen-9jy4AdFfT-0HPUV9m9LIWg is open
	2015-06-29 11:27:20.961  - INFO: ErizoController - starting erizoAgent 1
	2015-06-29 11:27:20.963  - INFO: ErizoController - erizoAgent pid 4966
	2015-06-29 11:27:20.966  - INFO: RPC - Queue erizoController_1 is open
	2015-06-29 11:27:20.968  - INFO: ErizoController - server on
	Running process
	Running process
	2015-06-29 11:27:21.051  - INFO: RPC - Exchange rpcExchange is open
	2015-06-29 11:27:21.054  - INFO: RPC - ClientQueue amq.gen-wTfxWqYStjXxu0JFa8itTA is open
	starting app, stdout -> /home/jin/Desktop/MCU_Release-v2.1.1/logs/woogeen-app.stdout
	Failed to setup secured server: [Error: mac verify failure]
- Tags:
 - HTML5
 - JavaScript*
Hi Yin,
It seems you've enabled SSL options. Did you generate and use your own keys with passphrase protection?
Thanks!
Had the same problem, problem solved running initcert.js in bin folder.
Tadas
Thanks, Tadas.
That's actually a step in the packaging script we provide. Have a try!
I have generated my own ssl server eventhough am gettin the following error please help me,
starting nuve, stdout -> /home/emphaticsense4/program_files/mediaServer_intelcs/Intel_CS_WebRTC.v2.8.1/localhost3/Release-v2.8.1/logs/woogeen-nuve.stdout
1096
	1139
	2016-02-26 12:05:06.857  - INFO: RPC - Conected to rabbitMQ server
	2016-02-26 12:05:06.869  - WARN: Nuve - Failed to setup secured server: [Error: mac verify failure]
	    at Object.exports.createCredentials (crypto.js:174:17)
	    at Server (tls.js:1128:28)
	    at new Server (https.js:35:14)
	    at Object.exports.createServer (https.js:54:10)
	    at /home/emphaticsense4/program_files/mediaServer_intelcs/Intel_CS_WebRTC.v2.8.1/localhost3/Release-v2.8.1/nuve/nuveAPI/nuve.js:1:2459
	    at Gunzip.<anonymous> (/home/emphaticsense4/program_files/mediaServer_intelcs/Intel_CS_WebRTC.v2.8.1/localhost3/Release-v2.8.1/common/cipher.js:1:769)
	    at Gunzip.emit (events.js:117:20)
	starting mcu, stdout -> /home/emphaticsense4/program_files/mediaServer_intelcs/Intel_CS_WebRTC.v2.8.1/localhost3/Release-v2.8.1/logs/woogeen-mcu.stdout
After generating your own cert, have you run the initcert.js script to initialize the cert with the correct passphrase?
Thanks!
Hi chunbo,
i have attached my woogeen_config file,please go through n correct me,what i have done wrong in tat
why we are creating https server both in basicServer.js and application.js file what is the need for creating two https server
w/o enabling ssl in woggen_config.js file am able to run the code,after getting token (ajax req)from basic server with that token and roomId trying to get connected with server.was stucked and stopped with tat not able to step in next steps
config.erizoController.port = 443 whether this port number and https server should be same?
Thanks^.
