For some reason. I'd like to use HTTP only for my MCU server. There are som configuration below according to doc.
portal/portal.toml
[portal] keystorePath = "./cert/certificate.pfx" # hostname = "" #default: "" ip_address = "my public ip" #default: "" # Port that the socket.io server listens at. port = 8080 #default: 8080 ssl = false #default: true force_tls_v12 = false #default: false, tls1 and tls1.1 will not be allowed if set to true #The network inferface the socket.io will be bound to in case portal.ip_address (the 'ip_address' item above) is not specified or equal to "". # networkInterface = "eth1" # How many seconds before Socket.IO client sending a new ping packet. This value might be overwrote by client side. # ping_interval = 25 #default: undefined # How many seconds without a pong packet to consider the Socket.IO connection closed. This value might be overwrote by client side. # ping_timeout = 60 #default: undefined # Life time for reconnection ticket. Unit: second. reconnection_ticket_lifetime = 600 #default: 600 # Client will leave conference if it cannot reconnect to Socket.IO server after |reconnection_timeout| seconds. reconnection_timeout = 60 #default: 60
management_api/management_api.toml
keystorePath = "./cert/certificate.pfx" superserviceID = "my superserviceID" ssl = false #if use HTTPS port = 3000 #default: 3000, port of server numberOfProcess = 1 #default: 1
management_console/management_console.toml
[console] #configuration for the management-console keystorePath = "./cert/certificate.pfx" ssl = false #if use HTTPS port = 3300 #default: 3300, port of manage console server [api] #configuration of management-api server secure = false #if server certificate is verified, set it to true. host = "http://localhost:3000"
And I got an error after I start-all
starting app, stdout -> /home/ubuntu/Intel_CS_WebRTC.v.4.2/Release-v4.2/logs/app.stdout
Build http(s) req error: { Error: socket hang up
at TLSSocket.onHangUp (_tls_wrap.js:1148:19)
at Object.onceWrapper (events.js:313:30)
at emitNone (events.js:111:20)
at TLSSocket.emit (events.js:208:7)
at endReadableNT (_stream_readable.js:1064:12)
at _combinedTickCallback (internal/process/next_tick.js:139:11)
at process._tickCallback (internal/process/next_tick.js:181:9)
code: 'ECONNRESET',
path: null,
Do I misunderstanding something? Any help will be very appreciated.
- Tags:
- HTML5
- JavaScript*
