Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Suggestions for testing frame works (Automation)
Chandramouli_P
I understand that there are some testing frameworks are available to test the applications which is developed using native WebRTC (webrtc.org). Could you please suggest any testing frame works (automation) especially to test the applications which is developed using Intel CS for WebRTC (Web, Android, iOS)?
Thank you.
Chandramouli.
YanbinZ_Intel
We use test framework IATF - Interative API Test Framework to handle cross-platform API automation test scenarios.  We plan to open source this framework later.  If you only want to test single platform , you can use  Karma+ Jasmine for JavaScript ,  Androidjunit4 and AndroidInstrumentationTestRunner for  Android ,  qtest for Windows SDK , XCTest for iOS SDK
Chandramouli_P
Any help would be appreciated.
Thank you.
Chandramouli.
Chandramouli_P
Thank you.
Chandramouli.
YanbinZ_Intel
Chandramouli_P
Hello Yanbin,
Thank you very much for your reply and information.
Thank you.
Chandramouli.
