- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
When trying to publish a video stream to the 4.3.1 server. I get the following error.
2020-07-07 04:52:34.193 - DEBUG: SocketIOServer - notify participant: ubVqNjvVfjxalJtcAAAA event: progress data: { id: '460436543263609700',
status: 'error',
data: 'Ice procedure failed.' }
I have seen a few other posts with this error, but it is not clear if these issues were ever resolved.
I am using a TURN server to connect to the MCU. The client is using the latest version of chrome canary.
I have turned on logging on the server and the client. The server is portal.txt and the client is client.txt
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I should also mention that in portal.toml, I have
force_tls_v12 = true.
However, based on some of the webrtc logs, it appears that tls_v12 is not being used. Not sure if this should matter or not, but her is an excerpt from the attached webrtc log
2020-07-07 04:51:32.754 - INFO: WorkingNode - pid: 15493
2020-07-07 04:51:32.759 - INFO: WorkingNode - Connecting to rabbitMQ server...
2020-07-07 04:51:32.814 - INFO: AmqpClient - Connecting to rabbitMQ server OK, options: { host: 'localhost', port: 5672 }
2020-07-07 04:51:33.635 - INFO: InternalConnectionFactory - QUIC is not enabled for internal IO
2020-07-07 04:51:33.659 - INFO: WorkingNode - webrtc-013ada7b31c85d4c15f0@10.0.2.15_0 as rpc server ready
2020-07-07 04:51:33.665 - INFO: WorkingNode - webrtc-013ada7b31c85d4c15f0@10.0.2.15_0 as monitor ready
(process:15493): libnice-CRITICAL **: 04:52:34.073: file address.c: line 166 (nice_address_set_port): should not be reached
(process:15493): libnice-CRITICAL **: 04:52:34.139: file address.c: line 166 (nice_address_set_port): should not be reached
2020-07-07 04:52:34,185 - WARN: dtls.SSL - failed in error
2020-07-07 04:52:34,185 - ERROR: dtls.DtlsSocket - SSL error 1
2020-07-07 04:52:34,186 - WARN: dtls.DtlsSocketContext - DTLS Handshake Failure error:1410241A:SSL routines:dtls1_read_bytes:tlsv1 alert decode error
2020-07-07 04:52:34,186 - WARN: DtlsTransport - id: 460436543263609700, message: Handshake failed, transportName:video, openSSLerror: error:1410241A:SSL routines:dtls1_read_bytes:tlsv1 alert decode error
2020-07-07 04:52:34,186 - ERROR: WebRtcConnection - id: 460436543263609700, message: Transport Failed, transportType: video
2020-07-07 04:52:34.187 - WARN: Connection - message: failed the ICE process, code: 502, id: 460436543263609700
2020-07-07 04:52:34.187 - WARN: WrtcConnection - ICE failed, 500 460436543263609700
2020-07-07 04:52:34.778 - WARN: WorkingNode - Exiting on SIGTERM
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I believe this is maybe happening because of some change that happened recently in chrome. I say this because, I have a version of the javascript that is packaged as a cordova app and it runs fine on Android. I have uploaded the logs for portal and client.
The only difference I can see is that the android app can complete the ice negotiation while the javascript running in chrome cannot.
I am using the following chrome canary version
Version 86.0.4195.0 (Official Build) canary (64-bit)
I guess I am at a loss as to why I get a handshake error with chrome canary but not cordova android app
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
