Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Is it a bug about publish limit
leo_a_
     I found a problem about publishLimit by using Android SDK communicating with MCU conference server, not sure it's a bug or not. The situation like this:
1,  set publishLimit = 1 in Test room which was just created.
2, user A join Test room, publish his local stream successfully.
3, user B join Test room, publish local stream. Then was notified publish success. after few minutes, onIceConnectionChange()  change status to FAILED, but callback is null in this ActionCallback publishCallback = (ActionCallback)this.pendingCallbacks.get(stream.getMediaStream().label()) ,onStreamActionFailed() of conferenceClient.class.
so the
if(publishCallback != null) {
    publishCallback.onFailure(e);
never get in. The caller never now published failed actually. I check the log file on MCU conference server, the woogen-portal.stdout show this:  INFO:SocketIOServer - emitted connection_failed, reason: controller.publish failed, reason: Too many publishers.
4, user B logcat of Android Studio :
6-20 14:56:44.213 26810-26852/com.lmdgame.lmdaudiodemo D/WooGeen-ConferenceClient: Publish stream
06-20 14:56:44.238 26810-15607/com.lmdgame.lmdaudiodemo D/WooGeen-ConferencePeerConnectionChannel: sendOffer
06-20 14:56:44.239 26810-26853/com.lmdgame.lmdaudiodemo D/WooGeen-PCFactory: Create PeerConnection.
06-20 14:56:44.244 26810-15608/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: Add Stream
06-20 14:56:44.245 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: onRenegotiationNeeded
06-20 14:56:44.246 26810-15608/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: Create Offer
06-20 14:56:44.252 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: SDPObserver ---- onCreateSuccess
06-20 14:56:44.255 26810-15136/com.lmdgame.lmdaudiodemo W/WooGeen-PeerConnectionChannel: No m=video  line, so can't prefer vp8
06-20 14:56:44.257 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: Found opus rtpmap 111, prefer at m=audio 9 UDP/TLS/RTP/SAVPF 111 103 9 102 0 8 105 13 126
06-20 14:56:44.257 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: Change media description: m=audio 9 UDP/TLS/RTP/SAVPF 111 103 9 102 0 8 105 13 126
06-20 14:56:44.280 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: PC Observer ---- onSignalingChange: HAVE_LOCAL_OFFER
        --------- beginning of system
06-20 14:56:44.282 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: SDPObserver ---- onSetSuccess
06-20 14:56:44.285 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: PC Observer ---- onSignalingChange: STABLE
06-20 14:56:44.295 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: onIceConnectionChange:CHECKING
06-20 14:56:44.298 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: PC Observer ---- onAddStream
06-20 14:56:44.298 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-ConferencePeerConnectionChannel: audio1  video0
06-20 14:56:44.298 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-ConferencePeerConnectionChannel: Weird-looking stream: com.intel.webrtc.base.LocalCameraStream@150e1b9
06-20 14:56:44.298 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: onIceGatheringChange:GATHERING
06-20 14:56:44.299 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: onIceCandidate
06-20 14:56:44.299 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: SDPObserver ---- onSetSuccess
06-20 14:56:44.300 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: onIceGatheringChange:COMPLETE
06-20 14:56:44.333 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: onIceConnectionChange:CONNECTED
06-20 14:56:44.333 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-ConferencePeerConnectionChannel: Change State=CONNECTED
06-20 14:56:44.334 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: onIceConnectionChange:COMPLETED
06-20 14:56:50.119 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: onIceConnectionChange:DISCONNECTED
06-20 14:56:59.409 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: onIceConnectionChange:FAILED
06-20 14:56:59.412 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-ConferencePeerConnectionChannel: StreamId=894402060054767100 dispose
06-20 14:56:59.417 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: onIceConnectionChange:CLOSED
06-20 14:56:59.417 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-PeerConnectionChannel: PC Observer ---- onSignalingChange: CLOSED
06-20 14:56:59.432 26810-15136/com.lmdgame.lmdaudiodemo D/WooGeen-ConferencePeerConnectionChannel: Change State=READY
leo_a_
Version 3.3.1 and 3.4 are the same behavior.
leo_a_
I found the solution on Version 3.4, by using the
onStreamError()
Please close this topic.
He_Z_Intel
onStreamError()
Thanks Leo,
prior to v3.4, Android SDK won't have any notification when the peerconnection fails after callback for publish/subscribe has already been triggered once.
in v3.4, onStreamError will be triggered as a notification for application, upon the MCU server detects any failure on the peerconnection after publish/subscribe. More info please refer to doc.
