Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Issue with Firefox
Naresh_R_1
Hi Lei,
With the firefox latest version camera access is getting failed, any work around for below error
navigator.mozGetUserMedia has been replaced by navigator.mediaDevices.getUserMedia
WebRTC interfaces with the “moz” prefix (mozRTCPeerConnection, mozRTCSessionDescription, mozRTCIceCandidate) have been deprecated.woogeen.sdk.js:9:11825
onaddstream is deprecated! Use peerConnection.ontrack instead.
Naresh
Lei_Z_Intel1
What Firefox version you are using?
Naresh_R_1
Hi Lei,
We are using Firefox version 49.0.1
Naresh
Lei_Z_Intel1
Which MCU and SDK version are you using?
Naresh_R_1
Hi Lei,
We used both latest 3.2.1 and 3.2 versions, we just configured MCU and tested with basic example
https://182.74.255.54:3004/?room=57fb767596d716130bde7bdd      -- v 3.2.1
https://182.74.255.52:3004/?room=57bd8b38233c480a53c26454      -- v 3.2
Naresh
Lei_Z_Intel1
We tried your server, it works well with Firefox 49, see attached screen shot file. We also got the warning log you showed, but that's just API will be deprecated in future warning, not error. Any more info you can provide on your client side?
Naresh_R_1
Hi Lei,
Issue exactly is local camera access getting failed with Firefox, have to published your local video from firefox?
Naresh
Lei_Z_Intel1
Is it possible related to your firefox setting? Any more logs besides the deprecated API warning?
Naresh_R_1
Hi Lei,
below is the log of firefox version  49.0.1
navigator.mozGetUserMedia has been replaced by navigator.mediaDevices.getUserMediawoogeen.sdk.js:8:20109
INFO: stream in conference: 57c3d98061bacd390c13ad3bwoogeen.sdk.js:8:9318
INFO: subscribing: 57c3d98061bacd390c13ad3bwoogeen.sdk.js:8:9318
INFO: stream in conference: 874069163808599200woogeen.sdk.js:8:9318
INFO: won`t subscribe 874069163808599200woogeen.sdk.js:8:9318
INFO: user in conference: Object { id: "/#LGHc0CyoUvSmFGahAAAA", name: "user", role: "presenter" }woogeen.sdk.js:8:9318
INFO: user in conference: Object { id: "/#r3zjLV8zutSuWFnyAAAB", name: "user", role: "presenter" }woogeen.sdk.js:8:9318
onaddstream is deprecated! Use peerConnection.ontrack instead.woogeen.sdk.js:9
Set remote and local description v=0
o=- 0 0 IN IP4 127.0.0.1
s=IntelWebRTCMCU
t=0 0
a=group:BUNDLE sdparta_0 sdparta_1
a=msid-semantic: WMS UTEbDA0lUq
m=audio 1 RTP/SAVPF 109 0
c=IN IP4 0.0.0.0
a=rtcp:1 IN IP4 0.0.0.0
a=candidate:1 1 udp 2013266431 182.74.255.52 59982 typ host generation 0
a=ice-ufrag:tF8b
a=ice-pwd:0PTrZFwMajpEcFSqzZhhG4
a=fingerprint:sha-256 7B:EA:EC:C5:C2:28:9F:EB:85:32:CB:62:72:D4:D6:47:DD:32:06:43:17:E3:AE:BE:34:45:E4:07:0B:96:CA:32
a=sendonly
a=mid:sdparta_0
a=extmap:1 urn:ietf:params:rtp-hdrext:ssrc-audio-level
a=rtcp-mux
a=rtpmap:109 opus/48000/2
a=rtpmap:0 PCMU/8000
a=maxptime:60
a=ssrc:1429165063 cname:o/i14u9pJrxRKAsu
a=ssrc:1429165063 msid:UTEbDA0lUq a0
a=ssrc:1429165063 mslabel:UTEbDA0lUq
a=ssrc:1429165063 label:UTEbDA0lUqa0
m=video 1 RTP/SAVPF 120 126
c=IN IP4 0.0.0.0
a=ice-ufrag:tF8b
a=sendonly
a=mid:sdparta_1
a=rtcp-mux
a=rtpmap:120 VP8/90000
a=rtcp-fb:120 ccm fir
a=rtcp-fb:120 nack
a=rtcp-fb:120 goog-remb
a=rtpmap:126 H264/90000
a=fmtp:126 profile-level-id=42e01f;packetization-mode=1
a=rtcp-fb:126 ccm fir
a=rtcp-fb:126 nack
a=rtcp-fb:126 goog-remb
a=ssrc:3429255293 cname:o/i14u9pJrxRKAsu
a=ssrc:3429255293 msid:UTEbDA0lUq v0
a=ssrc:3429255293 mslabel:UTEbDA0lUq
a=ssrc:3429255293 label:UTEbDA0lUqv0
woogeen.sdk.js:9:14065
INFO: Remote Description successfully setwoogeen.sdk.js:8:9318
INFO: subscribed: 57c3d98061bacd390c13ad3bwoogeen.sdk.js:8:9318
End of candidates.woogeen.sdk.js:9:12213
ERROR: create LocalStream failed: Object { code: 1100, msg: "SourceUnavailableError" }
Naresh
Lei_Z_Intel1
Such error usually happens when the user grants permission but a hardware error such as an OS/program/webpage lock prevents access webcam. For example, another program is using the webcam. How about double check your Firefox?
Naresh_R_1
Hi Lei,
It seems to be issue with my machine i updated to beta version 50 and it worked well. thanks for the support
Thanks & Regards
Naresh
