Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
MCU 4.1.1 Basic Example join room error
Naresh_R_1
Dear Team,
When we try to login to particular room using below URL we are getting error
Joining to another room except sample room using below URL we are not able to join
https://10.10.10.13:3004/?room=5c52a216b832ad250d7e8c88
index.js:139 server connection failed: Error: Joining room failed
    at new t (ics.js:9)
    at ics.js:9
Naresh
Li_C_Intel
Hi, Naresh
Are there any errors in logs
Naresh_R_1
Below are logs from conference
2019-01-31 16:51:00.425  - INFO: ErizoJS - pid: 23634
2019-01-31 16:51:00.430  - INFO: ErizoJS - Connecting to rabbitMQ server...
2019-01-31 16:51:00.451  - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: 'localhost', port: 5672 }
2019-01-31 16:51:00.713  - INFO: ErizoJS - conference-beb3823c5f889dc25f4d@182.72.126.189_2 as rpc server ready
2019-01-31 16:51:00.716  - INFO: ErizoJS - conference-beb3823c5f889dc25f4d@182.72.126.189_2 as monitor ready
2019-01-31 16:53:25.434  - ERROR: RoomController - new mix terminal failed. room_id: 5c52a216b832ad250d7e8c88 reason: Failed in scheduling video worker, reason: No worker matches the preference.
2019-01-31 16:53:25.445  - ERROR: RoomController - init fail. view: common reason: Failed in scheduling video worker, reason: No worker matches the preference.
2019-01-31 16:53:25.445  - ERROR: Conference - roomController init failed. Failed in scheduling video worker, reason: No worker matches the preference.
2019-01-31 16:53:25.445  - ERROR: Conference - Init room failed, reason: roomController init failed. reason: Failed in scheduling video worker, reason: No worker matches the preference.
2019-01-31 16:53:25.445  - WARN: Conference - Participant JnYvpJxHdNcqJTEFAAAC join room 5c52a216b832ad250d7e8c88 failed, err: roomController init failed. reason: Failed in scheduling video worker, reason: No worker matches the preference.
Naresh
Li_C_Intel
I guess your start a H264 mix stream without H264 support.
Use hardware MCU or install openh264 (video_agent/install_openh264.sh) on software MCU to have a try.
