Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Ankündigungen
MCU Confrence ERROR - subscribe failed unauthorized
Parveen_K_
Einsteiger
1.181Aufrufe
I am working on MCU server. I had installed MCU server on Azure as per MCU documentation. I am using https which is working fine.
I am trying to communicate between two users one is presenter and other is user. Here problem is while publishing stream. I am not getting remote stream at both side. I tried it Chrome to Chrome and Android sample app to Chrome which failed at both tests.
Please suggest what wrong I am doing?.
Here is console log on chrome :
This appears to be Chrome
script2.js?v=004:175 location:https://clients.georama.com/webrtc/conference/public/
script2.js?v=004:193 token: eyJ0b2tlbklkIjoiNTdhOTc5OTRlNmIzMjc4YjVmMTkwMTYyIiwiaG9zdCI6Im1jdS5nZW9yYW1hLmNvbTo4MDgwIiwic2VjdXJlIjp0cnVlLCJzaWduYXR1cmUiOiJaVFl4WWpVd1ltWTRZemhtWlRabU1qVXpOR1kxTkRjM01qQXlabVUzWmpoaE1XUmtaV1U0WXpreU9XUmtOMkpoTkdSaU9EZzFOalpoT0RJeFpURXdaQT09In0=
woogeen.sdk.js:8 INFO: stream in conference: 57a0631aa00f7da50afd0a58
woogeen.sdk.js:8 INFO: subscribing: 57a0631aa00f7da50afd0a58
woogeen.sdk.js:8 INFO: user in conference: Object {name: "user", role: "presenter", id: "/#yV84hHaGxnIX1ToRAAAs", permissions: Object}
woogeen.sdk.js:8 INFO: user in conference: Object {name: "user1", role: "user", id: "/#uza00a6JxmTIZ4dGAAAt", permissions: Object}
woogeen.sdk.js:8 ERROR: 57a0631aa00f7da50afd0a58 subscribe failed: unauthorized
woogeen.sdk.js:8 ERROR: publish failed: unauthorized
5 Antworten
Chunbo_H_Intel1
Mitarbeiter
1.181Aufrufe
Hi Parveen,
What do you mean by "https which is working fine"? Which version of MCU, Android SDK and Chrome you're using?
Thanks!
Parveen_K_
Einsteiger
1.181Aufrufe
Hi CHUNBO H.
My meaning was SSL certificate is added and SSL is working fine. But video publishing issue is exists either with https or http.
I am using version 3.1 for MCU, Android SDK, JS SDK. Chrome version is Version 52.0.2743.82 m
Thanks!
Chunbo_H_Intel1
Mitarbeiter
1.181Aufrufe
Are you using the self-signed certificate or a CA issued digital certificate on MCU?
Parveen_K_
Einsteiger
1.181Aufrufe
I am using CA issued digital certificate.
Thanks!
Chunbo_H_Intel1
Mitarbeiter
1.181Aufrufe
Hi Parveen,
Could you check the log on the MCU server? What kind of errors have been written into the server log?
Thanks!
Antworten
