Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
MCU REPORTS CONNECTION FAILED FOR STREAM
ANIL_K_3
Dear Team,
I installed MCU server on AWS and opened all udp incoming and outgoing and allowed all traffic and configured my server public ip in this places
1. in webrtc_agent/agent.toml: cluster->ip_address set to internal network ip address, webrtc->ip_address set to public network ip
2. in video_agent/agent.toml cluster->ip_address set to internal ip address
3. in audio_agent/agent.toml cluster->ip_address set to internal ip address
4.  in access_agent/agent.toml cluster->ip_address set to internal ip address
5. in portal/portal.toml, portal->ip_address set to public network ip
still i am  getting stream getting error as shown in attachement  . In Chrome only getting self view not getting subscribe stream, In firefox not even getting self  video and subscriber video
Ports Opened are :
tcp 0 0 0.0.0.0:42212 0.0.0.0:* LISTEN 19957/beam.smp
tcp 0 0 127.0.0.1:27017 0.0.0.0:* LISTEN 19086/mongod
tcp 0 0 127.0.0.1:28017 0.0.0.0:* LISTEN 19086/mongod
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 1012/sshd
tcp6 0 0 :::5672 :::* LISTEN 19957/beam.smp
tcp6 0 0 :::8080 :::* LISTEN 15778/node
tcp6 0 0 :::8081 :::* LISTEN 15778/node
tcp6 0 0 :::4369 :::* LISTEN 19919/epmd
tcp6 0 0 :::22 :::* LISTEN 1012/sshd
tcp6 0 0 :::3000 :::* LISTEN 15660/node
tcp6 0 0 :::3001 :::* LISTEN 16298/node
tcp6 0 0 :::3004 :::* LISTEN 16298/node
udp 0 0 0.0.0.0:59785 0.0.0.0:* 16015/woogeen_sip
udp 0 0 0.0.0.0:48525 0.0.0.0:* 16009/woogeen_sip
udp 0 0 0.0.0.0:68 0.0.0.0:* 640/dhclient
udp 0 0 0.0.0.0:22661 0.0.0.0:* 640/dhclient
udp6 0 0 :::10366 :::* 640/dhclient
So
Qiujiao_W_Intel
Kiranraj, thanks for the reply. Yes, we updated webrtc external network configuration setting, please specify network interface name and external ip.
BTW, please make sure ports for webrtc connection and internal streaming are open:
1. For internal streaming port setting (TCP), please set maxport and minport to opened port range in following files:
section internal in video_agent/agent.toml
section internal in audio_agent/agent.toml
section internal in webrtc_agent/agent.toml
for recording, rtsp and rtmp streamin, pelase modify port range in recording_agent/agent.toml or avstream_agent/agent.toml
2. For external streaming port setting (UDP), please set port range in section webrtc in webrtc_agent/agent.toml
Kiran_Raj_RA
Dear Anil
please look the below screenshot the webrtcagent.toml file does not updated the public-ip thats the reason video not getting out
Please check ip_address setting in MCU, for NAT network environment, you should follow configurations below to allow external access to MCU:
below shows how to assign public ip in mcu3.4.1v webrtcagent.toml
[{name = "eth0", replaced_ip_address = "1.2.3.4"}]
if rabbitmq is running in different machine in all toml file update the internal ip of rabbitmq server and add the below configuration in rabbitmq server to accept conections from other maches
/etc/rabbitmq/rabbitmq.config
[{rabbit, [{loopback_users, []}]}].
i think this will help you
Qiujiao_W_Intel
Daghe
3.5.2版本中
设置portal/portal.toml  ip_address为映射的外网ip   port改为映射的端口
webrtc-agent/agent-toml中webrtc
network_interfaces = [{name="eth0",replaced_ip_address=映射的外网ip"}]   这里的name为mcu中的网卡名称,还是外网的网卡名称
开启服务后,客户端请求portal模块中的ip+端口,请求websocket时无任何响应
https://外网地址:映射的端口/socket.io/?EIO=3&transport=polling&t=MBMuZxE
设置minport/maxport  若无上面的外网设置,仅设置端口,无法显示混合流画面 日志没有报错
nuve中的port是否需要映射到外网?
期待新版本的发布
Daghe
can you tell me your external network configuration setting?
