Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1152 Discussions
Makefile:1404: recipe for target 'libAACenc/src/aacEnc_rom.lo' failed ( CS_WebRTC_Conference_Server_MCU.v4.0.Ubuntu.tgz )
Ravi07
facing problem when i am running the > CS_WebRTC_Conference_Server_MCU.v4.0.Ubuntu.tgz >Release-v4.0>audio_agent>compile_ffmpeg_with_libfdkaac.sh
Output
libAACenc/src/aacEnc_rom.cpp:661:1: error: narrowing conversion of '2180108801' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:661:1: error: narrowing conversion of '2435191937' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:661:1: error: narrowing conversion of '2914591489' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:661:1: error: narrowing conversion of '3560484608' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:665:1: error: narrowing conversion of '2147483649' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:665:1: error: narrowing conversion of '2276992735' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:665:1: error: narrowing conversion of '2649899348' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:665:1: error: narrowing conversion of '3221225445' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:665:1: error: narrowing conversion of '3922060664' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:674:1: error: narrowing conversion of '2156644481' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:674:1: error: narrowing conversion of '2229462401' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:674:1: error: narrowing conversion of '2372618753' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:674:1: error: narrowing conversion of '2581238273' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:674:1: error: narrowing conversion of '2848216833' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:674:1: error: narrowing conversion of '3164462721' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:674:1: error: narrowing conversion of '3519206656' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:674:1: error: narrowing conversion of '3900368192' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:681:1: error: narrowing conversion of '2147483649' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:681:1: error: narrowing conversion of '2184048624' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:681:1: error: narrowing conversion of '2292498406' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:681:1: error: narrowing conversion of '2469139869' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:681:1: error: narrowing conversion of '2707957698' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:681:1: error: narrowing conversion of '3000819239' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:681:1: error: narrowing conversion of '3337751441' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:681:1: error: narrowing conversion of '3707280484' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
libAACenc/src/aacEnc_rom.cpp:681:1: error: narrowing conversion of '4096822497' from 'unsigned int' to 'FIXP_DBL {aka int}' inside { } [-Wnarrowing]
Ravi07
My System Configuration: Ubuntu 18.04 LTS, RAM-4GB,
 Using=====>                    Node: 6.9.5
                                           MCU( webRTC 4.0)
