Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Polycom SIP call video freeze
Larry_Y_
OS: CentOS 7.2;  MCU: 3.2; Polycom: HDX 8000 and RealPresence Group 550
No Gateway: 1) Polycom calls MCU via SIP account; 2) Both ends see and hear other other; 3) The polycom's video input always freezes after 1 second; 4) Both sides Audios always work, webrtc client's video input always work.
With Gateway: Same as above.
SIP calls with jitsi  is OK.
Please see attached for Logs.
Lei_Z_Intel1
We just got one PolyCom HDX7000 on hand, will start the investigation together with your log after PRC national holiday week. Thanks for your patience.
Larry_Y_
Hi Lei,
Thank you for looking into it. The SIP server we used is sip2sip.info.
Happy National Holiday!
Larry
Lei_Z_Intel1
Hi, Larry
We got HDX7000 video stream work well with basic VGA resolution. Can you share your detailed environment setting?
Best wishes,
Zhai Lei
Larry_Y_
Hi Lei,
We use VGA as well. We will set up a server so that your team can try.
With thanks,
Larry
Lei_Z_Intel1
Thanks Larry.
