Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Screen sharing recording
david_c_1
I can not record the video stream of desktop sharing.
I get the following error:
Media recorder failed: 584035089472308700 controller.subscribe failed, reason: streams do not exist or are insufficient.
Are there restrictions on recording a desktop stream?
Lei_Z_Intel1
Please paste or send your detailed log to us.
david_c_1
Woogeen logs do not report any
errors. I can only record the desktop
stream in forward mode, but not in
mixed mode. In the latter case I get
the mkv file but with a black video
when I share the desktop.
Lei_Z_Intel1
Now we only have one hybrid mode, which support both forward and mix stream. Can you describe more on you can't record in mix mode? Screen stream in mix stream or still the forward stream?
david_c_1
I've created an hybrid room.
In this room I want to record all streams: each video and screen user stream in forward mode and also the whole mixed stream.
Everything works correctly with the video streams of users: I get an mkv file for each video in forward mode and the mkv mixed stream file.
Otherwise if I start a screen sharing, I get the right single mkv file of the screen stream in forward mode, but in the mkv mixed stream file, this screen stream is recorded as black region for the entire duration.
David
Lei_Z_Intel1
Problem is did screen screen entered the mix stream. Did you see screen in mix stream when subscribe mix stream? Not like the video stream, screen stream will not enter mix stream by default.
david_c_1
Thank you for the reply.
Ok, now how can I get the screen stream into the mixed stream if by default this is not allowed?
Lei_Z_Intel1
Please use mix/unmix to control one stream whether should join mix stream after it's published. Detail refer the latest API guide.
david_c_1
Thanks a lot for the support. Now everything works properly
