We installed v2 server as it was descrobed in manual.
We try to start it,But we faced with errors in woogeen-agent.stdout:
2015-01-17 19:13:53.670 - INFO: ErizoAgent - Terminate ErizoJS e0fa3ba0-0700-052f-4f50-db14eadfb3fc callback events.js:72 throw er; // Unhandled 'error' event ^ Error: spawn EMFILE at errnoException (child_process.js:1001:11) at Process.ChildProcess._handle.onexit (child_process.js:792:34)
And created a lot of files like erizo-feda4fe6-cfd6-cfc6-0075-800ba63a91ff.log
with content:
axconfig: port 1 not active
axconfig: port 2 not active
Previously we used version 1 and 1.5 - all was ok.
What should we do?
链接已复制
Hi Artem,
Thanks for your continuous support on our products!
Regarding the issue you mentioned, do you run v2.0 on the same machine that has been used for our v1.0 and v1.5?
If yes, then you need to restart MongoDB and RabbitMQ before launching v2.0.
we tested on both examples:
on server where previously was 1 and 1.5 and on clean server.
To retest - we rebooted full server(where 1.5 worked) and tryed to start.
Start log:
oracle@vm2:~/Release-v2.0/bin$ sudo ./start-all.sh starting nuve, stdout -> /home/oracle/Release-v2.0/logs/woogeen-nuve.stdout 791 2015-01-18 16:12:26.841 - INFO: RPC - Conected to rabbitMQ server 2015-01-18 16:12:26.846 - INFO: RPC - Exchange rpcExchange is open 2015-01-18 16:12:26.852 - INFO: RPC - Queue nuveQueue is open 2015-01-18 16:12:26.856 - INFO: RPC - ClientQueue amq.gen-gUhXUsYJKJKsY7gu0-IEXq is open starting controller, stdout -> /home/oracle/Release-v2.0/logs/woogeen-controller.stdout 2015-01-18 16:12:28.600 - INFO: RPC - Exchange rpcExchange is open 2015-01-18 16:12:28.608 - INFO: RPC - ClientQueue amq.gen-Q16IfxwIR4rnvf98MoPOZW is open starting agent, stdout -> /home/oracle/Release-v2.0/logs/woogeen-agent.stdout Running process Running process Running process 2015-01-18 16:12:29.735 - INFO: RPC - Exchange rpcExchange is open Running process Running process 2015-01-18 16:12:29.753 - INFO: RPC - ClientQueue amq.gen-g_d_Lo7zcOnV0vwolHTcOH is open Running process Running process 2015-01-18 16:12:29.771 - INFO: RPC - Queue ErizoAgent is open starting app, stdout -> /home/oracle/Release-v2.0/logs/woogeen-app.stdout
And error in woogeen-agent.stdout
Running process 2015-01-18 16:12:33.231 - INFO: ErizoAgent - Terminate ErizoJS 8181fd0c-2e98-4005-d149-8449d1a5af6c callback child_process.js:948 throw errnoException(process._errno, 'spawn'); ^ Error: spawn EMFILE at errnoException (child_process.js:1001:11) at ChildProcess.spawn (child_process.js:948:11) at exports.spawn (child_process.js:736:9) at launchErizoJS (/home/oracle/Release-v2.0/mcu/erizoAgent/erizoAgent.js:1:1891) at ChildProcess.<anonymous> (/home/oracle/Release-v2.0/mcu/erizoAgent/erizoAgent.js:1:2083) at ChildProcess.emit (events.js:98:17) at maybeClose (child_process.js:756:16) at Process.ChildProcess._handle.onexit (child_process.js:823:5)
One question regarding "sudo" in start operation, I think it will bring different behaviors from non-sudo mode. We recommend to start server without sudo privilege.
If issue still exists, please pack all the log files and upload to us for further analysis and verification. Thanks!
In not sudo mode - test example starts, but video doesn't translating.
Log is in attachment.447103
woogeen-agent.stdout has error at the end:
2015-01-19 14:59:35.394 - INFO: ErizoAgent - Terminate ErizoJS 3813bac0-4b03-5f13-b50c-2ed5bcce5ccf callback child_process.js:948 throw errnoException(process._errno, 'spawn'); ^ Error: spawn EMFILE at errnoException (child_process.js:1001:11) at ChildProcess.spawn (child_process.js:948:11) at exports.spawn (child_process.js:736:9) at launchErizoJS (/home/oracle/Release-v2.0/mcu/erizoAgent/erizoAgent.js:1:1891) at ChildProcess.<anonymous> (/home/oracle/Release-v2.0/mcu/erizoAgent/erizoAgent.js:1:2083) at ChildProcess.emit (events.js:98:17) at maybeClose (child_process.js:756:16) at Process.ChildProcess._handle.onexit (child_process.js:823:5)
in javascript error is in
(woogen.sdk.js)
function e(a) {
b.call(this, a), this.isMixed = function() {
return !!a.video && "mix" === a.video.category
}, this.from = a.from
a.video.category - is undefined
Started server is in http://46.182.24.175:3001/
It seems the axconfig error message comes from Node.JS. Could you share the node version you are using currently? Where do you download the Node.JS package?
In most case, axconfig error happens if you install node from sudo. In this case, uninstall node by sudo apt-get remove node... and reinstall the right version node without sudo.
Thanks.You are right.
My WRANG way on installing nodejs was:
sudo apt-get install software-properties-common python-software-properties sudo add-apt-repository ppa:chris-lea/node.js sudo apt-get update sudo apt-get install nodejs -y
The RIGHT way of installing node is:
#installing tools for NVM sudo apt-get install build-essential libssl-dev #downloading nvm curl https://raw.githubusercontent.com/creationix/nvm/v0.16.1/install.sh | sh #relogin the bash #looking available versions nvm ls-remote #installing need version nvm install v0.10.26 #start script Release-v2.0/bin/start-all.sh
