Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
android crash : checkNoGLES2Error
tangk
Use sdk ver: 4.3 sdk
Below is the crash log
java.lang.RuntimeException:
at org.webrtc.GlUtil.checkNoGLES2Error (GlUtil.java:29)
at org.webrtc.GlShader.useProgram (GlShader.java:118)
at org.webrtc.GlGenericDrawer.prepareShader (GlGenericDrawer.java:244)
at org.webrtc.GlGenericDrawer.drawOes (GlGenericDrawer.java:157)
at org.webrtc.GlRectDrawer.drawOes (GlRectDrawer.java:14)
at org.webrtc.VideoFrameDrawer.drawTexture (VideoFrameDrawer.java:39)
at org.webrtc.VideoFrameDrawer.drawFrame (VideoFrameDrawer.java:209)
at org.webrtc.EglRenderer.renderFrameOnRenderThread (EglRenderer.java:584)
at org.webrtc.EglRenderer.lambda$vWDJEj1GWjHSjwoQQjEEK_IVOJE (Unknown Source)
at org.webrtc.-$$Lambda$EglRenderer$vWDJEj1GWjHSjwoQQjEEK_IVOJE.run (Unknown Source:2)
at android.os.Handler.handleCallback (Handler.java:883)
at android.os.Handler.dispatchMessage (Handler.java:100)
at android.os.Looper.loop (Looper.java:237)
at android.os.HandlerThread.run (HandlerThread.java:67)
* The latest webrtc library seems to have solved this problem by try catching it.
