Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
IntelMediaSDK2017forEmbeddedLinux-PV-MR4-B-02 Can not work on E3950
duncanchou
Hello Sir,
We get below message while doing  samaple_decode example of  IntelMediaSDK2017forEmbeddedLinux ,   but our VA-API version 1.7.0 from vainfo,
Could you help us fix this issue, may some steps we mistakes?
The test log is test_20200908.txt
Michael Wu
libva info: VA-API version 0.40.0
libva info: va_getDriverName() returns 0
libva info: User requested driver 'iHD'
libva info: Trying to open /usr/lib64/dri/iHD_drv_video.so
libva error: /usr/lib64/dri/iHD_drv_video.so has no function __vaDriverInit_0_32
libva info: va_openDriver() returns -1
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), CreateAllocator, CreateHWDevice failed at /opt/intel/mediasdk/samples/sample_decode/src/pipeline_decode.cpp:1277
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), Init, CreateAllocator failed at /opt/intel/mediasdk/samples/sample_decode/src/pipeline_decode.cpp:438
[ERROR], sts=MFX_ERR_MEMORY_ALLOC(-4), main, Pipeline.Init failed at /opt/intel/mediasdk/samples/sample_decode/src/sample_decode.cpp:720
-sh-4.4# vainfo
error: can't connect to X server!
libva info: VA-API version 1.7.0
libva info: User environment variable requested driver 'iHD'
libva info: Found init function __vaDriverInit_1_7
libva info: va_openDriver() returns 0
vainfo: VA-API version: 1.7 (libva 2.7.0)
vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 20.1.1 (54492c0)
vainfo: Supported profile and entrypoints
VAProfileNone : VAEntrypointVideoProc
VAProfileNone : VAEntrypointStats
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointFEI
VAProfileH264Main : VAEntrypointEncSliceLP
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointFEI
VAProfileH264High : VAEntrypointEncSliceLP
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointEncPicture
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointFEI
VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP
VAProfileVP8Version0_3 : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointVLD
VAProfileHEVCMain : VAEntrypointEncSlice
VAProfileHEVCMain : VAEntrypointFEI
VAProfileHEVCMain10 : VAEntrypointVLD
VAProfileVP9Profile0 : VAEntrypointVLD
duncanchou
Hello Sir
We do the sample code of  "IntelMediaSDK2017forEmbeddedLinux-PV-MR4-B-02", always get below error message,  and  get version information  is 0.40.0,
but our VA-API version is    VA-API version 1.9.0, not  0.40.0.
Anything we misunderstanding?
Does the  "IntelMediaSDK2017forEmbeddedLinux-PV-MR4-B-02"  be supported on VA-API version 1.9.0 ?
-sh-4.4#pwd
/opt/intel/mediasdk/samples/__cmake/intel64.make.release/__bin/release
-sh-4.4#./sample_decode h264 -hw -vaapi -i /mnt/nfsshare/camera_124_640x_480.h264 -o test.rgb
-sh-4.4#vainfo
libva info: VA-API version 1.9.0
vainfo: VA-API version: 1.9 (libva 2.7.0)
Michael
