Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
how switch camera in ios?
snow__fly
      hi!
          I use :
               self.myCamera = AVCaptureDevice.defaultDevice(withDeviceType: .builtInWideAngleCamera, mediaType: AVMediaTypeVideo, position: .front)
              let cameraid=self.myCamera?.uniqueID
              self.myCameraPar=RTCLocalCameraStreamParameters(videoEnabled: true, audioEnabled: true)
            // [parameters setResolutionWidth:352 height:288];
                self.myCameraPar?.setResolutionWidth(352, height: 288)
                self.myCameraPar?.setCameraId(cameraid!)
                self.localCanmerStream=RTCLocalCameraStream(parameters: self.myCameraPar!)
          I switch camera,but no success!
 let session =  AVCaptureSession()
            do {
                let    Input1 = try AVCaptureDeviceInput(device: self.myCamera)
                let    Input2 = try AVCaptureDeviceInput(device: self.myCamera2)
                session.beginConfiguration()
                session.removeInput(Input1)
                let b =  session.canAddInput(Input2)
                if(b)
                    session.addInput(Input2)
                    print("okOKokok")
                else
                    print("nononono")
                session.commitConfiguration()
                session.startRunning()
 I look at API  "RTCAVFoundationVideoSource" ,but I can not use.
        let t = RTCAVFoundationVideoSource.init(constraints: <#T##RTCMediaConstraints!#>)
            t?.useBackCamera = true
Ferhat_D_
I 've set source and localstream like below
source = RTCAVFoundationVideoSource(constraints: mediaConstraints)
source?.useBackCamera = true
localStream = RTCLocalCameraStream(audioEnabled: true, videoSource: source!, error: nil)
and after this just use useBackCamera (true|false)  inside my changeCamera() function. I didn't use any cameraParameter.
YanbinZ_Intel
For iOS SDK , switch camera can be done through set useBackCamera as Yes /NO
Following is example code , you can include it to your SwitchCamera() function and it will switch camera over successive calls when i is even or odd
    static int i = 0;
    NSDictionary *mandatoryConstraints = @{@"minWidth" : @"640", @"minHeight" : @"480",@"maxWidth" : @"640", @"maxHeight" : @"480", @"maxFrameRate":@"24", @"minFrameRate":@"24"};
    RTCMediaConstraints* constraints = [[RTCMediaConstraints alloc] initWithMandatoryConstraints:mandatoryConstraints optionalConstraints:nil];
    RTCAVFoundationVideoSource* source=[[RTCAVFoundationVideoSource alloc] initWithConstraints:constraints];
    if((i++)%2 == 1){
      source.useBackCamera = YES;
    }else{
      source.useBackCamera = NO;
    NSError *err=[[NSError alloc]init];
    _localStream=[[RTCLocalCameraStream alloc]initWithAudioEnabled:YES VideoSource:source error: &err];
snow__fly
Hi , Thank you all。   My problem has been solved
 let mandatoryConstraints = ["minWidth":"640","minHeight":"480","maxWidth":"640","maxHeight":"480","maxFrameRate":"16","minFrameRate":"16"]
                let constraints = RTCMediaConstraints(mandatoryConstraints: mandatoryConstraints, optionalConstraints: nil)
                self.mVideoSource = RTCAVFoundationVideoSource(constraints: constraints)
                self.mVideoSource?.useBackCamera = false
                self.mIsBackCamera = false
                self.localCanmerStream=RTCLocalCameraStream(audioEnabled: true, videoSource: self.mVideoSource!, error: nil)
func switchCamera()
            if mIsBackCamera
            else
                self.mVideoSource?.useBackCamera = true
                mIsBackCamera = true
                                                          Thinks!
Deepesh__NAik
How to switch camera in v4.0 of iOS client using ICSLocalStream?
krishna__venkata
Hello Team,
we are also having same issue, how to switch camera in v4.1 for using ICSLocalStream?
Jianjun_Z_Intel
Hi Deepesh and krishna,
ICSLocalStream can be initialized with a RTCMediaStream. You can switch position on its associated RTCCameraVideoCapturer.
krishna__venkata
Hello Jianjun,
Thanks for your reply,
with out using initialise with media stream working good.
           let constraints = ICSStreamConstraints.init()
           constraints.audio = true
            constraints.video = ICSVideoTrackConstraints.init()
            constraints.video?.frameRate = 24  //need to check waht is heighest and lowset and why we need to set
            constraints.video?.resolution = CGSize(width: 640, height: 480) //is based on device we need to change, its our local stream resilution
              if self.isFrontCam == false {
                constraints.video?.devicePosition = .front //as per out camera we need to set front or back, by default its setting as front
            else{
                constraints.video?.devicePosition = .back //as per out camera we need to set front or back, by default its setting as front
            var errorObj : NSError?
           self.localVideoStream = ICSLocalStream.init(constratins: constraints, error: &errorObj).  //local video stream is created
            localVideoView.captureSession = captureSource.captureSession //RTCCameraVideoCapturer also started
         self.localVideoStream.attach(self.remoteVideoVioew!)  //local stream is getting renderview.
But as per the response if we created the ICSLocalStream with  RTCMediaStream,for local itself its not adding to renderview getting only black scrren.
For this after hitting the Join Api in the response we will get conference information objection, that object is subclass of ICSStream(which contains mediaStream object). As we check with  the stream object it doesn't contains any RTCMediaStream, project is getting crashed.
Sample code :
            let icsSourceinf = ICSStreamSourceInfo.init()
            icsSourceinf.audio = .mic
            icsSourceinf.video = .camera
            let remoteStreamObj = currentConfInfo.remoteStreams.first as! ICSRemoteStream
            rtcMediaStream = remoteStreamObj.mediaStream as? RTCMediaStream
             if rtcMediaStream == nil {
                rtcMediaStream = localVideoStream2.mediaStream // to resolve the crash checked the condition and added localstream
            localVideoStream = ICSLocalStream.init(mediaStream: rtcMediaStream!, source: icsSourceinf)
Please help us how to use ICSLocalStream with media object.
As we noticed this method contains peer connectivity properties, our aim is to create conference call.
JJ_Lin
same here.
Would like to switch camera position while conference call.
Seems Android SDK has a method called switchCamera but iOS hasn't.
Trying to find some solution. Stuck here for almost a week. :'(
K__Srujan
Hi Team,
I have the same issue. Kindly, give us an update, to solve the above?
Jianjun_Z_Intel
Hi krishna,
The issue may be fixed by https://github.com/open-media-streamer/oms-client-native/commit/98c9c31f34b162774bec0abb89364011df06c885. But it is not included in v4.1.
K__Srujan
Hi Jianjun,
Thanks for your response.
We are using v4.1 SDKs for iOS,Android and Server side and we cannot depend OMS Client.( i.e the link you given above).
Does it have any possible solution using your SDK / WebRTC SDK which you have provided?
krishna__venkata
Hello Jianjuan,
How to fix the issue, we cannot find solution in v4.1.1. for ICSLocalStream to switch camera. If we republish the local stream for one instance its working fine. If we trigger same call again with out restart the application the remote itself not binding to opposite device getting issues as
2019-02-06 17:45:27.604415+0530 VideoConf_Swift[9961:1784648] Failed to make complete framebuffer object 8cd6
2019-02-06 17:45:27.604732+0530 VideoConf_Swift[9961:1784648] Failed to bind EAGLDrawable: <CAEAGLLayer: 0x281c9c640> to GL_RENDERBUFFER 1
How to resolve this issue, please help us
Jianjun_Z_Intel
Above commit is included in v4.1.1.
张__俞
    static int i = 0;
    if((i++)%2 == 1){
    }else{
RTCAVFoundationVideoSource and RTCLocalCameraStream dose not provide in WebRTC.framework,how can i get it ?thank you very much!
张__俞
snow f. wrote:
Hi , Where can I find RTCLocalCameraStream? thanks
func switchCamera()
            if mIsBackCamera
            else
                                                          Thinks!
Lai__Jing
hi guys,
Regarding camera switch on iOS, did you manage to do that without republishing?  We are struggling, and getting stuck.  If any of you be able to do that, would you kindly share the source code block implementation?  Thanks in advances!
K__Srujan
Hi Jianjun,
How are you?
Could you please give us sample example for creating local stream with RTCMediaStream, as we are unable to create local stream with it.
Kindly do the needful as it is high priority issue from our end.
K__Srujan
Hi Jianjun,
How are you?
Any update would be appreciated?
K__Srujan
Hi @Jianjun Z.
Could you please help us out by giving an example of creating local stream with RTCMediaStream?
K__Srujan
Hello Team,
